I have a 92 with a manual transmission. that I have blown the engine in. I am having problems finding another to go back in it. I don't really need any more power, but would anyone know what other vehicles have that size motor that will bolt back to the mounts?
92 Isuzu Rodeo 3.1 Engine
As far as I can tell ALL Gen I and II FWD motors use the same exact block. But the upper end on the Rodeo uses iron heads and TBI fuel injection from the S-10. So it is a hybrid motor of sorts. If you do choose a Gen II FWD motor as a core then you wont be able to use the pistons with the stock heads. The Camaro also used a 3.1L but the starter is not on the correct side and not all the engine mount bolts line up. So it is better to use a FWD block.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Early-to-mid '90's GM FWD mini-vans use a 3.1 cast-iron-head TBI motor which will bolt right up to your Rodeo, providing it's using an Isuzu MUA tranny with starter on the driver's side. There are 2WD 3.1 Rodeos using a right-side starter along with a BW tranny and for that you could use a Camaro 3.1 or 3.4. But I'm thinkin' since you're having trouble finding a motor that you're probably looking for the FWD-style block.
One other thought, the Trooper 2.8 block found in '89-91 V6 models has the same bore as a 3.1, if you were to find a good 2.8 block you could install a 3.1 crank and pistons, and the Troop block will bolt right up to a Rodeo MUA-5 tranny.
HTH.................ed'90 Trooper 3.4 Conversion, bored intake, Holley Big-Bore, 1.6:1 Small Block Chev V8 roller-tipped rocker arms.
3.1 Block and Crank
I have a good 3.1 Block and Crank out of a 92 rodeo with driver side starter . If you are interested email me zed2869@hotmail.comOriginally posted by leamaltizer View PostI have a 92 with a manual transmission. that I have blown the engine in. I am having problems finding another to go back in it. I don't really need any more power, but would anyone know what other vehicles have that size motor that will bolt back to the mounts?
