Originally posted by Driver_10
View Post
3400/325 e30...project GMW!
i plan on playing with e85, theyre 65# at 43psi motron injectors.[SIGPIC]
12.268@117... 11's to come!
If your squirting E85, those #65's wont be good for any more than 350hp crank, maybe 400 tops. Im running a set of #80 or #85 at least. Im expecting 600hp or so at the crank on corn juice.Originally posted by MidnightriderZ24 View Posti plan on playing with e85, theyre 65# at 43psi motron injectors.
How much power you looking to make?Took a break from working on the car. Got some better tools, got a better shop, got a better job... Its time to burn metal!
How about using an Army issue canteen with a threaded pipe fitting ontop for the coolant jug...!? Leave the shoulder strap n all on it. Should be good for 16 psi Easley if it's army issueLast edited by bob442; 12-25-2012, 10:51 AM.
funny you say that, i was considering it, and have been, but i like the idea of airbrushing the vw bottle look like a grenade (done be somebody professional. The nitrous tank will be painted to look like a bomb too...fitting the theme well.Originally posted by bob442 View PostHow about using an Army issue canteen with a threaded pipe fitting ontop for the coolant jug...!? Leave the shoulder strap n all on it. Should be good for 16 psi Easley if it's army issue[SIGPIC]
How about cutting a old bomb or shell in half and seeking it inside it. I do like the idea I a hand Grenade idea, but I don't think it will turn out how you think it will. And plastic that gets heated won't hold paint for ever. IMO. If you hunt around you should be able to get a de commissioned shell for cheap. Good luck. I am addicted to looking up this thread every day.
few small updates, radiator hoses all sized up and together, radiator modified for the new lower inlet. after chasing a no spark condition, i got it narrowed down to a bad msd box (fuck). Removed the coil interfaces and put some e85 in it, and she runs! Lots more to do yet so stay posted!
VIDEO: http://s433.photobucket.com/albums/q...114_191745.mp4
[SIGPIC]
Outstanding! A few questions...
When did you buy your MSD-4 plus? I ask because I have a similar unit that also doesn't work.
What cam grind are you using? I remember having a conversation about it once before and I think we both have the same cam.
What are the build and mod specs of your MegaSquirt engine controller? I modified my box for e85 sensor input and was curious as to whether or not you were doing the same.Took a break from working on the car. Got some better tools, got a better shop, got a better job... Its time to burn metal!
Sick radiator!
. I'm not sure if you were planning on buying a new msd box or not. Before you do, contact them
. The box in my dragster took a dump this season and I sent it out to them and they repaired it for me. Didn't charge too much.. I think the # was (915) 855-7123. I hope this helps get the car on the road
cam grind is the old stage 4 turbo cam from Ben. the MS is a MS1 2.2 extra with knock sense built in. im workin on a ms3-X for next winter install, which will be sequential injection, LS CNP ignition, table switching for e85 and setup a 3 stage launch control, boost by gear etc. Thanks for the number on the msd, it cant hurt to send it out and see if its an easy fix.[SIGPIC]
Ive got a much milder cam. Ben's old "street strip" turbo cam to be exact. Im using a MS2 controller with two step launch control (like yours) and flat-shift. Youll have to tell me how you configured yours for gear specific boost control.Originally posted by MidnightriderZ24 View Postcam grind is the old stage 4 turbo cam from Ben. the MS is a MS1 2.2 extra with knock sense built in. im workin on a ms3-X for next winter install, which will be sequential injection, LS CNP ignition, table switching for e85 and setup a 3 stage launch control, boost by gear etc. Thanks for the number on the msd, it cant hurt to send it out and see if its an easy fix.
Got a link for the mod?Took a break from working on the car. Got some better tools, got a better shop, got a better job... Its time to burn metal!
im still working on using a momentary switches setup and the ms connector. still in the works. next thing im worried about is getting my driveshaft made and braking system plumbed, then onto finishing more interior wiring.Originally posted by Driver_10 View PostIve got a much milder cam. Ben's old "street strip" turbo cam to be exact. Im using a MS2 controller with two step launch control (like yours) and flat-shift. Youll have to tell me how you configured yours for gear specific boost control.
Got a link for the mod?[SIGPIC]
