Flywheels
  • trotterlg
    • Feb 2011
    • 326
    Flywheels
    What standard transmission flywheels will fit a 3.1 swap into a Fiero? Are the 4 cylinder flywheels the same? How about the 4's that was in the S-10, or the V6 S-10's? Are any of them different weights? I know about the internal balanced and external balance engines, I need a neutral balanced wheel. Larry
  • neophile_17
    • Jun 2004
    • 306
    Hello,
    I went to RockAuto and cross-referenced the flywheel for an 88 Fiero (internally balanced) and it was installed in a lot of things including 2.2L Cavaliers and 2.2L S10s. I got mine at the JY from an S10 for < $10. Would I pull a tranny again to save $40, not likely. I did get all the bolts though...
    ~sam
    • trotterlg
      • Feb 2011
      • 326
      Thankyou, I thought someone would know about these things. I will start my search. Larry
