Sunbeam Alpine 3.4 swap questions
  • Alpine John
    • Jul 2012
    • 1
    I have a ''66'' Alpine and a 94 Camaro 3.4 ,5 speed donor car. If I use the camaro drive line but put a 2000 or newer 3.4 or 3.5 behind it,are there fly wheels available for the externaly ballanced 3x00 motors?If so what car/motor combos did they come in? Also will the upper intake manafolds on the 3x00 motors bolt on 180 degrees rotated for rear wheel drive configuration? Lastly will the ecm,s from 3x00 motors work with standard transmissions? I would be greatfull for any info./wisdom.
    Thanks
  • shapeshaver
    • Jun 2006
    • 34
    Hi John, I am doing the same thing in my '62 series II alpine and you can see my pictures at http://www.sunbeamliger.weebley.com but you should also check out my post on this forum here http://60degreev6.com/forum/showthre...pump-specifics. much of what you have asked for is covered in that thread.
    What are you going to do about having to modify the steering when using this engine?
    1962 Sunbeam Alpine
    www.lx9alpine.com
    LX9 swap in progress
