3100 Intake swap
  • chevelle3504speed
    • Aug 2010
    • 6
    3100 Intake swap
    Hi,
    I have found a good bit of information about upgrading a '94 M code 3100 by installing the J code 2000 or later intake on it. I have a J code 3100 out of an 02 Century that I want to install my '94 model intake on. I realize this is backwards from a performance standpoint, but I have to get this car back on the road in a hurry. Has anyone tried this? Are there clearance problems between the newer style roller rocker arms and the older '94 model intake?
    Thanks,
    Andy
    • 9191
    There aren't issues with the roller rockers. The issue you will run into is with the EGR and heater coolant pipe. Take a look at those 2 things before you go too far.
    Brad via Tapatalk
