So I pulled the 2.8 from my Fiero..Put in 3.1 crank,bored 40 over and with higher compression pistons,444 cam and headers..Also ported and polished Plenum,runners and heads..The power increase was more than I planned on..I wasnt trying for a race car, just an improvement..For the low cost and not a bunch of time, it was well worth it..I jus wanted to post this for anyone else thinging of doing this..
2.8 stroker works great..
Tags: None
Pics please. And thank you for building a not so loved engine. I sure miss my 3.1! I had big plans for that engine on the rebuild.95 Beretta 3100 with 3400 intakes and TCE TB
Grand Prix trans with 3.33FDR
Its actually still the 2.8 engine, just stroked with a 3.1 crankshaft..I like the reliability of the 2.8 intake system and gaskets so I didnt use any of that stuff from a 3.1..I will post a few pics..
Yep, 2.8's and 3.1's are the same block.. all 3.1's are stroked 2.8's.
Yes, plus a good performance cam and 40 over high compression pistons..Its around a 3.3 liter now..
compression ratio calc says 3206cc.Originally posted by tntprocomp View PostYes, plus a good performance cam and 40 over high compression pistons..Its around a 3.3 liter now..
Yep. not much more though.. i've heard of .060 after a very thorough inspection but at that point it's just easier to start with a 3.4 block.
