Supercharged 3.1 in a Sonoma
  • caffeine
    replied
    Well we got this thing started this morning at about 4AM lol. Took a vid with my phone but it didn't save. Oh well.
    Engine bay is kinda a mess right now and we still have to build charge piping but the hard part is over! Fired up first try!
    Fuel lines
  • geoffinbc
    replied
    All RWD setups with serpentine belts. So 86 or 87 and later have reverse rotation pumps. 2.8L's have long nose pumps for mechanical fans. 3.1L and 3.4L Camaro's have short nose pumps because they had E-Fans.
  • caffeine
    replied
    Ya I think all 3.4s have CCW rotating pumps
  • dskopek
    replied
    I am running the 3.4 Camaro pump the same way as Superdave.
    replied
    was gonna say, mine's a 3.4 Camaro pump and it's like this...
  • caffeine
    replied
    The pump is from a Fiero. They all have CW Rotating pumps
  • Mars
    replied
    yeah, it's a reverse rotation pump, they were on Camaro 3.4's I think...
  • caffeine
    replied
    It's a CW rotating pump we just don't have a 6-rib pulley for it yet. Threw the 3.1 WP pulley on for now.
    Had a 5-rib pulley on it originally
    replied
    Your driving a smooth pulley with the ribbed side of the belt? That doesn't make sense to me, and dave is right the WP will not be spinning in the right direction.
    Smooth pulley, Accessory rotates counter-clockwise, Ribbed pulley Accessory rotates clockwise with the crank.
    replied
    It's early and i haven't quite woken up yet... but are you sure your water pump is going to spin the correct way?
  • caffeine
    replied
    All accessory mounts have more-or-less been finalized. SC mount was re-done, and PS pump bracket is now completely custom to allow the alternator to swing down a little more.
    Tensioner
    PS Pump
    SC Mount
    Measuring belt length
    Coil mount
    Wiring more-or-less finished
    Accessories all figured out!
    Motor installed permanently
    Didn't bother finishing it up because one of the fuel fittings didn't arrive in time. It really just needs to be put together and intake piping finished.
  • caffeine
    replied
    Ya that belt isn't the one we're actually using. Just something to help us align the pulleys. The tensioner should place the pulley as close to the crank pulley as possible which should wrap the charger nicely.
  • stargaazer7467
    replied
    maybe an idler and a tensioner, to get more belt wrap on that charger.
    replied
    that belt is almost as long as a northstar timing chain.
  • caffeine
    replied
    Unfortunately didn't get much done on Wednesday, but got the sc mount mostly finished and worked on other accessory mounts as well. Wiring is mostly finished.
    Frame notch boxed in
    Wiring progress
    Still have to add in a tensioner but mostly finshed
