3.4 front wheel drive engine work in rear wheel
  • dboerst
    • Feb 2014
    • 4
    I got a great deal on a 3.4 front wheel drive engine and want to install in a 1966 Datsun roadster. I have a t-5 5 speed tranny and was wondering is it possible to use this engine for rear wheel drive? On the deal I got a 454 but I don't think that will fit......This is my first post. Any info will be greatly appreciated!
  • caffeine
    • Jan 2012
    • 1489
    Yes it's possible. The most common method is to use a RWD 2.8/3.1/3.4 timing cover/water pump/balancer and flip the lower/upper intakes 180*. Some minor mods to the timing cover are necessary. It can be run with an OBD1 or OBD2 PCM.
    '86 Fiero, 3500, 4-speed
    • caffeine
      • Jan 2012
      • 1489
      The most ideal T5 to use IMO is a mustang T5 with a 94-95 S10/Sonoma bellhousing. Another option is the F-body 3.8 bellhousing/trans.
      If you use an earlier bellhousing/trans you will need to cut some material away to clear the FWD starter location. A friend did this on his truck and it was fine.
      • dboerst
        • Feb 2014
        • 4
        Thanks for the information. Do you know if it is possible to get a real 250 to 300 hp out of a 3.4? I know zero about V6 engines. Small block guy but with todays' gas prices, 2 cylinders less seems possibly the way to go.
        • caffeine
          • Jan 2012
          • 1489
          Yes but how far are you wanting to go with building it?
          • dboerst
            • Feb 2014
            • 4
            Engine is going into a Datsun 1600 roadster body. Size of a MGB. Are there factory hi-po heads? I figure equal length headers, after market intake, forged pistons-if available. Was there a turbo ever produced for a 2.8-3.4 V6? I have a shortened 9in ford rear end with 4:11 gears. Any ideas on a somewhat of a budget?
            • caffeine
              • Jan 2012
              • 1489
              A turbo will easily get you to 300 hp and more. Best flowing heads/intakes from the factory are from the 3500. There are forged pistons available but unless you're going for high compression you don't need them for 300hp.
              • dboerst
                • Feb 2014
                • 4
                Thanks for the info do you know the casting #s of the 3500 heads you are talking about? What car would I be looking for to find the engine you have mentioned? I really appreciate your input!
                • caffeine
                  • Jan 2012
                  • 1489
                  04-06 Malibu, 05-06 G6, 05-06 Uplander/Montana/Relay, and some others
                  • Guest
                    Always great to see more Datsuns.
                    Have any pictures?
                    Here's mine:
                    Currently has a turbo L28 (N/A version, running GM EFI, including DIS), I do have a 3500 that will be going in it eventually.
                    • BMC
                      • 146
                      Sounds like a neat project. There are tons of 3.4L RWD engines in MGBs and a few of the 3400 engines as well. I am a frequent poster on another website for MGs that has plenty of discussion about said engine swaps. The car will be VERY fast even with just a stock V6. The 1600 and the MGB are both very light cars and it doesn't take much to make them very quick.
                      -BMC.
                      MG & MGB V6 + V8 Engine Conversion Shop
                      1982 Chevrolet S10 long box with another L32 SFI!
                      1980 MGB with Camaro L32 3.4L SFI V6
                      2000 Venture 3400 (for her)
                      Spitfire L32 3.4L
                      "Experimentals"
                      and more conversions all the time.
