LZ9 swap possibility
  • fat rabbit
    • Jul 2013
    • 44
    I have a 2010 impala LT with the 3.5L flexfuel engine(LZE) Looking on craigslist for parts I ran across someone selling a 3.9L with the trans, subframe, harness and ECM/TCM from a 2010 impala police car.
    Would it be plug and play or is there some differences like in the wiring/programing that make it not work?
    1997 Chevy Lumina LS- SOLD
    Mods:3400 cylinder heads, 01 upper & lower intake, 56mm throttle body, 22.5lbs injectors w/ 55psi regulator, 1' 3/8" thick radiator, tuned with lower fan temps by wot-tech
    2010 Chevy Impala LT
    Mods: LGD swap, 3.29 standard duty differential, 33 37 drive sprockets, Don Rome brackets, front and rear GMPP strut tower braces, GMPP 22mm front sway bar, GMPP 19mm rear sway bar and tune from Over Kill Motorsports
