It ran ...twice
  • neophile_17
    • Jun 2004
    • 306
    It ran ...twice
    Hey guys,
    First a little background- this car is 6 hours from me so I need to plan things out a little more than I otherwise would. The car itself is an 85 Fiero with an LX9, WOT Street/Strip Cam, and headers.
    Saturday evening I finished everything needed to try and start her up. She fired up on the second crank which was amazing and honestly a little surprising. However, after tidying up some loose ends Sunday I went to finish bleeding the coolant and the engine started idling lower and lower until it died. I tried a couple things but in the end I had to pack up and head home before doing a thorough diagnosis.
    One of the things I did Sunday was connect vacuum to the valve cover breather since I don't have a pre-throttle body connection anymore. Is there any chance I kept oil from draining back into the pan and starved the engine?
    My impression is that something is dragging in the engine. Any ideas on what could have gone wrong. I know I'm lacking in information but it's killing me considering how close I thought I was.
    Thanks for your insight!
    Sam
    watch fuel pressure the next time you key on? i've seen a failing pump do nearly the same thing.
    and by vacuum to the valve cover, do you mean full manifold vacuum at all times?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Pull the plugs. Might have been over fueling or filling cylinders with coolant.
      • neophile_17
        • Jun 2004
        • 306
        Thanks guys.
        Fuel pressure will be first on my agenda since it's the easiest to test. Yes full manifold vacuum. As soon as it stopped running I plugged the TB connection and left the valve cover open to atmosphere. It still didn't start after that.
        I did smell the tailpipe to see if I could smell gas from an overly rich condition, and I tried flood clear mode. It's still possible but I'm leaning away from overly rich as the culprit. Hopefully I didn't mess anything up badly enough to fill the cylinders with coolant when I put it back together. I guess I'll find out when I go to do a compression test.
        • caffeine
          • Jan 2012
          • 1489
          Not having vacuum hooked up to the valve cover will not affect oiling in a significant way. The factory PCV system does not create a vacuum in the crankcase it merely circulates air through it.
          '86 Fiero, 3500, 4-speed
          • neophile_17
            • Jun 2004
            • 306
            I was afraid it might affect oiling in a negative way- keeping the oil from draining back into the pan and starving the pump. I'm still a little concerned that that might be the case :-/
            • caffeine
              • Jan 2012
              • 1489
              Not at all. Nothing to be concerned about
