trans swap
  • beppe180
    • Jul 2004
    • 82
    trans swap
    i was wondering if it was poss to use the tranny from the malibu in a w body 88 grandprix? if yes wut would i need to do it
    thanks,
    beppe
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Yea but where are you gonna get the electronics to run it? You would need to remove the old ECM and rewire the car for a PCM to control everything.
    Not and easy swap. But I supose it is doable.
    • beppe180
      • Jul 2004
      • 82
      i suppose the harness wont just plug in to the old harnesses place and run in throughout the car. like say 1 from a 94 grandprix or 95 with the 3100 in it. will the harness plug in?.. i will run the wiring and mod some if i have tooo
      • geoffinbc
        • 5831
        No its not like Lego.
        If you could find a mechanical tranny and not an electronic one then the swap would be much easier.
        Did they make a 4T60 (no "E") this tranny would be an easier swap if you are looking for a 4 speed auto.
        • beppe180
          • Jul 2004
          • 82
          ok thanks guys
          • sharkey
            • Jun 2004
            • 2061
            just a side note here, the 4t60 was originaly called a 440t4. gm updated the name in the early 90s to 4t60, but it was the same tranny. a couple years later, they came out with the 4t60e (e is for electronic)
