Temp Sensor Tap Size
  • twistedindy1
    • Apr 2004
    • 57
    We did a 3400 swap on the motor and still have problems getting the temp gauge to work right...so I am just going to tap out the thermostat houseing and put the sensor in there for now, but I need to know the tap size...Can anyone help me with that...It is from a 90 beretta with the two wire sensor...Marc
    Marc
  • twistedindy1
    • Apr 2004
    • 57
    if anyone cares to know it is 14mm with 1.5 pitch...
    Marc
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Dude. You are suposed to install a 3 wire snesor and wire up your temp guage and ecm to that. Then you dont have to hack up your manifold.
      • Guest
        And last time I checked the tap needed was a 3/8" NPT.
        • geoffinbc
          • 5831
          LOL yea it is NPT it is not a straight thread thats for sure. And GM never uses metric pipe thread.
          • twistedindy1
            • Apr 2004
            • 57
            the 14 is what I used and worked perfect...no standard sizes would work, just the metric...maybe I had a different sensor than the rest of you.
            Marc
            • Rhedalert
              Dr. Feelgood
              • 1574
              I changed over to the 3-wire sensor on my Olds just for the sake of a more accurate reading.
              Brian
              3400 SFI V6, 4T60e
