T5 Spline Count for 60degree's
  • RebelGT
    • 642
    Does anyone know the spline count for the input shaft needed for the 60degree v6's? I'm going to be looking for a T5 now that I realised the 4 cylinder 2.2 tranny sucks balls.
    26+6=1
  • RidgeRunner
    • 971
    I've got a T5 from an 85-86 Camaro sitting in the garage back home, I'll count the splines when I get there for this weekend if that'd help you any.
    60v6's original Jon M.
    • RebelGT
      • 642
      awesome! as long as its a V6 I don't see why it shouldn't work for me
      26+6=1
      • evilmiata
        • Nov 2003
        • 156
        All T5s are 14 spline until the 93+ 3.4l in the Camaro, which is 26. However, the 93+ uses a Ford-style case and will not bolt up to an earlier bell housing.
        Edit: According to Clutch.net, the early Camaro tranny uses 14 splines 1"1/8 long. A 2.2l S10 uses 14 splines 1" long. An easy way around this is to use a Camaro flywheel.
        • RebelGT
          • 642
          evilmiata, so which would be the optimal setup? I'm trying to bolt up to a 3.4dohc.
          26+6=1
          • evilmiata
            • Nov 2003
            • 156
            What are you putting it in? If its an S-10, I'd use a (ta-dah!) S-10 bell housing. A Camaro bell housing will NOT work without major fabrication since the transmission mount is rotated 15*. This was done so the shifter would be closer to the driver (a concern in a wide chassis).
            On a side note, The 83-85 Jeep Cherokee bell housing will bolt up to the Mustang/93+ Camaro tranny. However, these bell housings are difficult to come by. I would have used one in my conversion if I could have sourced one (I was sent the wrong bell housing twice!).
            Use a T5 from a S-10 or a -92 Camaro. However, only one will work! You'll have to be the judge of that. While the bolt patterns are the same, the shifter location is not; the S-10 shifter is in the middle of the transmission while the Camaro is by the output.
            You should also check the starter location on the DOHC block. I believe the FWD and RWD motors had the starters on opposite locations. If you have your heart set on DOHC, www.killerbv6.com had a custom bell housing that might help you.
            • RebelGT
              • 642
              The drivetrain is going into a chevette, and yes the starter is on the drivers side. I figure I would like to use the V6 camaro bellhousing since it has the dual starter bulges to accomidate the FWD starter as is. The fact that it is rotated, I'm not sure if that will cause me a problem or not. I think what I really should find out is what spline count the 2.2l 4 cylinder tranny has, because I think I'd want to use that internal slave cylinder if problem to avoid the problems of the clutch fork sticking straight out instead of downish which the stock chevette one did.
              26+6=1
              • evilmiata
                • Nov 2003
                • 156
                As I mentioned before, I am using a 93-95 camaro bell housing. The 15* offset required me to modify my shifter.
                I can't guarantee that a Camaro bell housing will fit a FWD starter. However, it probably wouldn't hurt to cut a notch in the bell housing for the starter. The material covering the starter doesn't appear to be structural and probably acts as a dust cover (I hope!).
                Again, what is the 2.2l tranny from? Visit www.Clutchnet.com.
                • RebelGT
                  • 642
                  the 2.2l tranny is from a later model S10, they came with the inherently same engine as the cavalier. So its a FWD engine in a RWD truck, so the tranny is perfectly setup for this. The only problem is that the tranny's are not easily rebuilt like that of a T5.
                  26+6=1
                  • Scott_68B
                    • Nov 2003
                    • 147
                    I'm using the Camaro bellhousing on a GEN II 3.1 in my MGB conversion and I can tell you that it will fit. You'll have to do a little grinding on the starter pocket if you're using the stock starter but it wasn't a big deal.
                    -- Scott
                    • Piper106
                      • 25
                      You might also want to look at the Transmission section of the message board.
                      There was a thread titled "Chevette Swap" started by Vincentujak dated May 21, 2004.
                      There is another thread "RWD Bellhousings" started by Smilingguy99 dated March 22, 2004.
                      Most of the ground you guys are looking at was already plowed in those two threads.
                      Piper106
