Custom for sure-especially if you're going to have them domed as much as you are.
High Compression [b]Propane[/b] 60/V-6!
You can run flat pistons. The valves will not touch. As was discussed before the valve will hit the edge of the piston where there is no bowl so if you fill in that bowl it makes no difference. V6ho has good pics explaining what im trying to say.
What is the lift on that cam. You should be able to get close to .6 lift at the valve with no problem. Springs may need to be changed though.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
V6ho is Colin. He is on this board.
Mahle might have flat top pistons. What compression are you aiming for like 14-16:1?1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
what if you used the dohc pistons would that get it close? maybe you just need custom gaskets after that.If you aren't friends with a liar, you aren't friends with anyone.
