Isuzu Trooper 3.4 swap
  • Duchauler
    • Dec 2004
    • 1
    I am swapping my GM 2.8 for the camaro 3.4 in my 1990 Isuzu Trooper. I was going to go with alum heads but I have heard the my TBI setup will not work. If th heads and pistons are used, circa 1998, what kind of efi would it take to make it work? Or is it alot easier to use my TBI set up with the Holley TBI in place of my 2.8 TBI?
    Peace,
    Duchauler
  • firechiken
    • Feb 2004
    • 557
    RE: Isuzu Trooper 3.4 swap
    Stick with the TBI. And as far as the Holley set-up, do you think it would make that much of a difference? I would try the 4.3 TB swap instead.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Agreed. If this is your first swap keep the TBI.
      Instead of the Holley intall a 4.3L TB. It is HUNDREDS of dollars cheeper.
      And here is how you do it http://members.shaw.ca/betterthanyou/28to43/28to43.htm
