2.8 FI To Carb
  • ibuildnoleaks
    • Feb 2005
    • 6
    2.8 FI To Carb
    I've got a 2.8 out of an 86 Fiero gt, I'll be putting this engine into a Sandrail but I dont want to have to deal w/ all the wires, I have an intake off of an 82 2.8 as well as the carb and distributor I plan on using an electric fuel pump will these parts interchange, i was really wondering about the distrubutor on how to hook it up but will the intake match up? hoses dont really matter i can route them where ever i want any help would be appriciated thanks.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Yes everything will work fine. All your parts are from the same generation motor. Nothing to really worry about.
    • ibuildnoleaks
      • Feb 2005
      • 6
      how about some info on the hei distrubutor, im a mopar guy so the hei is kinda different anyone got a wiring diagram? i got the distributor and coil off an 82 S-10 engine but there is a wire missing i cant tell where it goes. Once again thanks in advance
      • geoffinbc
        • 5831
        Is the spare wire white? It may be the tach wire.
        It is hard to say without seeing it. I will be able to get you a diagram when I get home.
        • ibuildnoleaks
          • Feb 2005
          • 6
          a diagram would be awesome thanks!
          • geoffinbc
            • 5831
            This is the best I could get. Its hard to find stuff for 82-85
            • ibuildnoleaks
              • Feb 2005
              • 6
              i dont see anything
              • ibuildnoleaks
                • Feb 2005
                • 6
                now I do, this should work thanks
                • Arns85GT
                  • Feb 2004
                  • 140
                  You need to change distributors
                  When I did my conversion on my 85 Fiero 2.8, I used a Chevy Blazer vacuum distributor. My carb is the Holley 2300 on an Edelbrock intake.
                  My electricals are essentially Blazer electricals without the Fiero ECM and that spaghetti wiring harness.
                  I think my distributor was out of an 85 Blazer, but it could have been any early 80's Blazer 2.8 distributor before they went electronic.
                  Arn Brown
