new motor for the z24?
  • Wolf
    • 181
    ever sence the motor in my z24 locked up, I've been torn betwen junking the car, or putting a new motor in it and fixin it up.(btw it needs a lot o fixin)I can find 3x00's in the junkyard all day long,but one thing that stops me from gitting one is evry swap site i've seen says you need custom mounts the put the 3x00 in,I don't see why you can't use the front cover and motor mounts from the gen 2 motor on the gen 3?
    1995 camaro 3.4 5-speed
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    the mounts that it needs bolts to the block. the actual casting of the block is differnt so the one you have doesnt bolt to it. i think you need the oil pan as well, and that might be the deciding factor in the timing cover selection.
    you could swap in a 3.1 and start with that, go hybrid, or just slap a turbo on with modest boost, that would be fun. thats what i should have done...
    • Guest
      As stated the mount bolts to the block, not the front cover.
      The oil pan does not need to be changed, in fact it can't be, bolt pattern is VERY different in the genIII 660
      • Doubt_Incarnate
        • Jan 2005
        • 1130
        so you have to use the 3x00 pan?
        how about the timing cover?
        is it just the front mount that needs fabbed up or the rear too?
        i can get a 3100 for $100, so im jumpimg on it, i just need to figure out the "how" to make it fit someday.
        How is the raven, did you finish it? i was dormant for a while, i pobably missed it.
        • Wolf
          • 181
          so the blocks mounting points are diferen't on the gen 2 & gen3 motors?
          (IE the gen 3 dosn't have the bosses for the gen 2 mounts?)
          • Doubt_Incarnate
            • Jan 2005
            • 1130
            correct
            • geoffinbc
              Iron Head Enthusiast
              • 5831
              The whole 3400 fits really nicely in a Cavalier. Chris's mount is sweet. Buy it. I can vouch for its effectiveness
              • Wolf
                • 181
                how much dose it cost? (and a link) can the 2.8 computer run the motor?,and can I mod the intake to take the 2.8s egr?(adapter plate?)
                • geoffinbc
                  • 5831
                  Um I think it is on www.domesticcrew.com or something.
                  2.8L computer will run the 3400 yes. However it is probabally best to change to a 3.1L chip and injectors if possible. Or better yet go custom chip.
                  Plates are not a problem to adapt the EGR. With a chunk of 1" aluminum you could make one.
                  • Cliff8928
                    • 532
                    My 3400 is still running acceptably on the 2.8 computer and chip, the EGR is blocked off, there's no really good way to fit it in there. And to switch to the 3.1 chip, you'll have to change the EGR over to the digital one.
                    Cliff Scott
                    89 BerettaGT
                    04 AleroGX
                    Cliff Scott
                    89 BerettaGT
                    04 AleroGX
                    • sharkey
                      • Jun 2004
                      • 2061
                      also depending on the year, to change to a 3.1l ecm, you may need to change the wiring harness.
                      the 3x00 will run fine off a 2.8l ecm.
                      • Wolf
                        • 181
                        hmm, still can't find a price on the motor mount
                        I need to keep an eye out for a 96-99 3400... and all the other various lil nink naks
                        hehe, gonna need something to drive while the camaro get the dohc swapped in
                        • Wolf
                          • 181
                          if I can find a good gen 2 3.1(gonna look this thursday), i'm gonna put it in, I just need something to drive while I play motor swap with my camaro
                          • Doubt_Incarnate
                            • Jan 2005
                            • 1130
                            heres the motor mount for a gen3 into a z24:
                            get it while its on sale!
                            • geoffinbc
                              • 5831
                              Yea and you might get it next year.
                              Talk to Chris he will sent you the mount in no time.
