3400 passes emissions test with no modifications
  • Cliff8928
    • 532
    Just thought I'd let everyone know that to my surprise, my 3400 in my '89 Beretta passed the emission test today. It was fairly close to the limit, but i didn't even expect it to pas with NO modifications at all, still running the original 2.8 chip. I've also been a little lax about changing the oxygen sensor as well, (as in, the 7 years i've had it i never changed it).
    Cliff Scott
    89 BerettaGT <- Good on emissions until 2007
    04 AleroGX
    Cliff Scott
    89 BerettaGT
    04 AleroGX
  • korbendallas68
    • 3400swap.com •
    • 553
    Pretty cool. How does it run with the 2.8 chipset?
    1995 Grand Am GT
    3400 V6 / 4T60-E / Engine Swap
    3400 Engine Swap Guide Version 2.5 is Available!
    www.3400swap.com
    • Wolf
      • 181
      nothing better than getting passed the emission nazis
      1995 camaro 3.4 5-speed
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        Lloyds 1990 3400 passed better than the 3.1L
        • Cliff8928
          • 532
          It runs acceptably on the 2.8 chip still.. I'm sure it's not optimal, but no stock chip is. I was just surprised that it passed the "IM240" test before the whole test was completed... now that i think of it, that is better than the 2.8 did.
          However, i do need a new ECM and some other stuff. out of the blue i'll lose any power whenever the accelerator is off idle, I just have to reach over and tap the ECM then it's back to normal.
          Cliff Scott
          89 BerettaGT
          04 AleroGX
          Cliff Scott
          89 BerettaGT
          04 AleroGX
          • Cliff8928
            • 532
            I scanned in the results if anyone cared...
            Cliff Scott
            89 BerettaGT
            04 AleroGX
            Cliff Scott
            89 BerettaGT
            04 AleroGX
            • 86JeepXJ
              • 19
              Interesting test results..... Check this article out. You may find it helpful....
              1986 Cherokee Wagoneer 4 door.
              2.8 Litre V6 TF904/NP228
              4.10 gears
              • patgizz
                The Plaid Bandit
                • 1071
                which injectors?
                • Cliff8928
                  • 532
                  My injectors are what were in it. I didn't loosen a bolt on the engine i didn't have to. The engine was from a '99 Alero, so they're the Multec design (the style used from 87-99)
                  Cliff Scott
                  89 BerettaGT
                  04 AleroGX
                  Cliff Scott
                  89 BerettaGT
                  04 AleroGX
