Distributor to DIS swap
  • EMX5636
    • Jan 2005
    • 50
    I tried the search button but since I am rather new here, it didn't seem to point me in any direction at all. So I am trying this. I have a 2.8 iron head in my Fiero, I am running a Haltech E6GM with it but I am using a 2.8 gen 2 aluminum head block. I was wondering what I needed to add to convert to the dis. I have the crank sensor and I have a DIS pack off my spare 3.4 tdc. If I do the necessary wiring for the ecm, Do I have everything necessary to do the swap? thanks to all in advance.
    Justin W
    1988 Fiero Formula - 3400sfi with an intercooled 60trim, Haltech, water/meth
    1990 Mitsu Eclipse GSX - parted out
    1991 Galant VR4 #108/2000 - Slammed sedan, built everything
    1995 Kawi Ninja zx7r
    1992 S10 4x4 - lowered/bagged, the dd
    2004 450R MX quad
    • 9190
    RE: Distributor to DIS swap
    You can effectivily hook up the DIS exactly like the distributor was hooked up... Let's see if I can find 2 diagrams to explain:
    Here is the distributor wiring to the ECM:
    And here is the DIS wiring to the ECM:
    If you look at the circuit numbers, all of the wires are there. All you need to do is hook them up as shown between the 2 diagrams.
