Beretta to Sunbird
  • 89Sunbird
    • 12
    Beretta to Sunbird
    I am dropping a V6 into my Pontiac Sunbird (currently has a 2.0 OHC), and I found a 3.1 5spd Beretta at a local yard. A quick look and it looks like the mounts are the same, but I am wondering if there would be any fabrication required to do the swap?
    I know I will need an ecm, and fuel pump in addition to the engine and wiring.
    Anything else I will need to know?
  • Guest
    No, no reall fabrication.
    I'm assuming that you found a '90 or '91 Beretta, since those are the only two years that have the 3.1 and use the same mounts as the J-body.
    When I did the swap in my 1985 Skyhawk I used a 1990 Pontiac Tempest as a donor.
    I had to modify the winging harness slightly for it to work in the J-body.
    I'll make one recomondation though, and that is to use a newer 660, like the 3100 or 3400.
    For info on that swap look at www.domesticcrew.com
    • 89Sunbird
      • 12
      Yeah, forgot to say its a 1990 Beretta.
      I had heard that because the Sunbird (1989) uses an electronic speedo, I can probably make it work with the Beretta ecm, just wiring in a new connector....what are your thoughts on this?
      • Guest
        Yep, should work no problem, since I tested a Sunbird speedo that I later aquired and compared it to the L-body Speedo, worked fine.
        BTW, the wire for the speedo will already be a plug in the wire, going to the ECM, all that may be required may be a pin location change in taht plug.
        • 89Sunbird
          • 12
          Sweet, thanks!
          • 89Sunbird
            • 12
            Okay, another question...a guy can hook me up with the ECM off an 89 Cavalier with a 3100 SFI...will it work on the 3.1 MPFI?
            • Guest
              89 Cavaliers were never equipped with a 3100.
              Did this guy swap in a 3100, and use the stock ECM, any custom programming?
              If you're going to be running a stock 3.1, then use stock programming.
              • 89Sunbird
                • 12
                Now he says its a 3.1MPFI :P Im guessing it was a swap.
                • 89Sunbird
                  • 12
                  Okay, it was an engine swap...
                  • Guest
                    That's also not an '89.
                    • 89Sunbird
                      • 12
                      Im just gonna quit posting what he says while Im behind :P
                      • Guest
                        LOL At newest it's an '87.
                        • sharkey
                          • Jun 2004
                          • 2061
                          could be a newer car with a 1st gen front clip on it.
                          • 89Sunbird
                            • 12
                            Yup, 1st gen. BUT! My 89 had a 1st gen front end
                            • sharkey
                              • Jun 2004
                              • 2061
                              yea that doesnt count. sunbirds pre 89 all used 1st gen front clips.
                              what i mean (wich im sure you have figured out) is a 1st gen cavy clip on a 2nd gen cavy/bird.
