So, uh, WTF? (pic) and fuel line question
  • Calvin
    3.77 1st gear sucks...
    • Feb 2006
    • 61
    [img] http://www.cardomain.com/member_page...071_2_full.jpg [/img]
    So I picked up my 3400 for my 89 GP Friday, and it has these weird abominations sticking out of the area around the exhaust ports on the heads. At first I thought they were EGR, but upon looking at them they look more like they are coolant passages that feed the heater core antifreeze from where it gets heated up the fastest....? Am I right? If so can I yank that garbage off and run a conventional style heater loop? Are the threads of the holes in the heads NPT? Anyone?
    Thanks
    Kurt
    PS What did y'all do when it came to be time to hook up your quick connect fuel line from the new rail to the old screw in car lines?
    Thanks again,
    Kurt
  • sharkey
    • Jun 2004
    • 2061
    the pic is kinda small, but i think those are airpipes. that would mean the motor is a california emmisions motor, and used an airpump. you can yank em right off, but i dont beleive the ports are pipe thread.
    for fuel lines, most people cut off the quick connects from the 3400, cut the fuel lines that are on the old motor and join them with a compression fitting, so you have the screw together fittings on the 3400 fuel rails.
    • CNCguy
      Bisong eater :P
      • 1017
      Sharkey is right about them being air tubing. Just get four 1/2-20 set screws to plug the holes. I used 1/2" long stainless ones in mine.
      MinusOne - 3100 - 4T60E
      '79 MGB - LZ9 - T5
      http://www.tcemotorsports.com
      • Calvin
        • Feb 2006
        • 61
        Thanks!
        Now I just have to figure out what the hell a California motors was doing in Grand Rapids, MI
        • Calvin
          • Feb 2006
          • 61
          00+ fuel rail pressure is what, 55PSI?
