will the 3.1 engine in a 98 olds achieva come out through the top?
  • durangoman
    • Jul 2006
    • 9
    im getting ready to take out my old worn out 3.1 will the motor come out through the top? can i just unbolt the motor from the tranny and leave it in place and just lift out the motor?
    thanks
    • 9190
    Yep. I've done it at least twice...
    • Calvin
      3.77 1st gear sucks...
      • Feb 2006
      • 61
      Yes, you can but make sure to get the engine good and far away from the trans before you lift it up significantly so you don't damage the torque convertor by pulling up on it by the center nub that sticks into the back of the crank in the center of the flywheel.
      • Rhedalert
        Dr. Feelgood
        • 1574
        Also make sure you support the passenger-side of the tranny from underneath, before you pull the engine out. My friend has a '97 Skylark, same platform as the Achieva, and he got it out the top easily. You may have to undo the hood supports if the car has it, and prop the hood higher.
        Brian
        3400 SFI V6, 4T60e
        • durangoman
          • Jul 2006
          • 9
          thanks everybody for the great info!
