rim offset? biger or smaller to move the tire out?
  • ProjectMM
    • Mar 2004
    • 170
    I'm looking at geting a new set of light weight rims. 8.5 in wieth what offset should i be lloking at, I'd lick the tires almost to the fender?
    2002 Pontiac GrandAm GT1
    3400 v6
    TOG headers
    RSM 62MM T-body
    FFP underdrive pulley
    GRANATELLI MAF
    Ported upper intake
    MSD DIS 4 ignition box
    MSD Wires and coils (pending)
    Venom high flow fuel pump (pending)
  • mfuller
    Mr. Common Sense
    • Nov 2003
    • 374
    Stock offset is +42mm; you want to move closer to +35mm. Test fit if at all possible before buying though.....I only went to an 8" wide rim (+35mm offset, 225/45R17 tires) and things get tight at full steering lock.
    Matt
