Spongy brakes...
  • ryan.hess
    • 526
    Spongy brakes...
    I just did the rears (replaced a caliper, both rotors, and pads). I've always had crappy braking before, and doing this hasn't affected much. I have a 93 with ABS, so I followed the haynes instructions, "primed" the abs, bled the brakes, and bled the ABS module. Everything according to instructions, and got all the air out. But it still feels spongy, and the pedal goes 75% down to the floor before braking occurs... It would be impossible for air to still be there - I bled it twice, and did the "start engine to initialize ABS to free air bubbles" procedure twice as well. Do I need a new MC? Do you still think there's air in it?
    Okay now, that's enough of that.
  • Cliff8928
    • 532
    Did you adjust the rear piston out to the pads correctly? If i remember right, you have to do this or else the brakes don't work good at all..
    Cliff Scott
    89 BerettaGT
    89 Volvo740
    Cliff Scott
    89 BerettaGT
    04 AleroGX
    • Anonymous
      Cliff Scott
      89 BerettaGT
      89 Volvo740
      What do you mean? I don't recall adjusting anything at all...
      • ryan.hess
        • 526
        heh... whoops... didn't log in. Didn't know you could do that.
        • Cliff8928
          • 532
          I haven't done it before myself, but a friend told me about somethin with turning the piston back out somehow in the back to properly adjust the rears so the pedal feel was normal..
          Cliff Scott
          89 BerettaGT
          89 Volvo740
          Cliff Scott
          89 BerettaGT
          04 AleroGX
          • blk92z34getrag
            • 515
            When I replaced my front rotors I just took the cap off the master cylinder and used a C-clamp to push the piston back... worked for me. That should work for the rears as well.
            --Rob
            • ryan.hess
              • 526
              Yep, that's what I did. I took it to a shop to have them test drive it, and they were like, "the brakes are fine... I've seen much worse"... I guess I just demand higher standards I'm gonna replace the front rotors and pads, anybody know what size Torx bit the caliper mounts take? It's huge - larger than my bigest T50...
              • Juglenaut
                • 1130
                To set rear piston simply activate the park brake several times, and after each set push and hold the brake pedal for 10 seconds or push the pedal while setting the park brake. 5 reps should do it, then re-check for air in the caliper or dirty oil and bleed off some oil for giggles, then set the rear park break a few more times and it should be good.
                I am back
                Mechanical/Service Technican
                • Lyle's GTP
                  • Jan 2004
                  • 1345
                  It's a T60, your best bet is to go to a bargain tool store and get a brake socket set. It will be cheap and will have a T60 in it.
                  Lyle
                  • Juglenaut
                    • 1130
                    I have a whole set of Torx bits 50 ain't gonna do it.
                    I am back
                    • ryan.hess
                      • 526
                      Lyle
                      Got it. Replaced the rotors and pads in front, and I'll try that technique to set the rears tomorrow. Fun fun!
                      • Cliff8928
                        • 532
                        You used a C-Clamp to compress the piston in the rears? Something's not right here...
                        For the rears you should have to turn the piston while pushing to get it in correctly...
                        Cliff Scott
                        89 BerettaGT
                        89 Volvo740
                        Cliff Scott
                        89 BerettaGT
                        04 AleroGX
                        • ryan.hess
                          • 526
                          Cliff Scott
                          89 BerettaGT
                          89 Volvo740
                          Well, technically it did turn as it went in.. at least the right did, I replaced the left with a new caliper so it was ready to go.
