Rear suspension sound...
  • PCGUY112887
    • Feb 2006
    • 1067
    Car/Mods in sig.
    All of a sudden today, when braking I can hear a "clunk clunk clunk" sound in my rear right tire area. It will start clunking right when I start to hit the brakes from say 40mph, and will last a moment or 2 then it will stop as I brake harder to come to a stop.
    It will also make this noise in hard turns, even when not braking, and sometimes when going over a large bump.
    To be honest, it sounds like my back tire is kinda loose (yes I know what this sounds like!). However, all of the lugs felt tight.
    Idearz?
    SpudFiles
    Theopia
    Enjoy life online.
  • gpse3400
    • 1460
    You probably wore out the leaf spring end tip bushing. You can check undernieth the car by the knuckle. Rock Auot sells replacents, heres the number 5763600 Spicer.
    Lorenzo
    • PCGUY112887
      • Feb 2006
      • 1067
      That's the little rubber shoe that goes over each end of the leaf correct?
      If so I thought about that too... when I built the car at least. I had to put the Moog pucks in there on my old sedan due to this exact noise... so I checked when I built the car and they were fine but maybe it's worn now
      SpudFiles
      Theopia
      Enjoy life online.
        Check your hub/bearing too.
