13' brakes for w-bodys
  • d.o.h.c
    • Jun 2004
    • 981
    I am tired of the w-body brakes, they suck. I have powerstop rotors, hawk pads and SS lines and my brakes are good but not excellent. So I am wanting to use these--
    and design custom mounting brackets to use. I would be just selling the brackets, proabably $100 for the 2 and they would be some high quality steel so there would be no worreis about them cracking or what ever.
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    Adapters is all you need for that brake swap? I want to see the end installed result. I'm in.
    I got a set of 18" wheels but I also have a set of Stock 16" with Brand new Drag radials .
    Fuck it, i'm in AFTER you install yours and put some miles on it.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      ehh, i don't need no stinking brakes. i'll just make mine handle better then i will not need to stop.
      seriously, it looks very interesting but nothing i will pursue at the moment.
      • OldSkoolGP
        That guy over there
        • 930
        You'd have to make them for the 95-99 front strut housings as well, they use a different adapter with slightly bigger brakes. And you don't want to just go putting 13" brakes on the front without upgrading the rears as well, at least 11.5" for balance.
        • d.o.h.c
          • Jun 2004
          • 981
          Yeah, but I just wanna see if these make a difference.
          • MidnightriderZ24
            • Jan 2005
            • 699
            i think its a safe bet that they will make a difference.........
            [SIGPIC]
            12.268@117... 11's to come!
            • OldSkoolGP
              That guy over there
              • 930
              Oh it will make a difference. Just upgrading from the stock 91-94 brakes to the 95-99 brakes all around made a huge difference!
              • gpse3400
                • 1460
                Regardless of what you put on there you are still going to have that same pedal feel, which is a general trait of vacumm boosted brakes... I've always felt a bigger master cylinder is the way to go....
                I dont have any issues with my brakes...I use full cast rotors and quality pads. For the rears I run the stainless steel sliders which for the past 10 years I'm still using the same brake calipers. Different cars though hehehehe
                Lorenzo
                • OldSkoolGP
                  That guy over there
                  • 930
                  Well that is a huge problem with the W cars. The booster is far too powerful and it blows the seals in the master. I put a new master on mine this spring and I remember the moment it blew out the seals, I could feel the pedal instantly get mushy, and it's been that way since. When it was working I could easily lock up all four wheels, but under hard braking I still have enough to lock up the rears.
                  • gpse3400
                    • 1460
                    Unfortunately for my car that has ABS I cant swap out master cylinder..atleast not the way I'd like to do it....I'm thinking an old M/C from an old late 80's G body might work. They use the same booster but a bigger M/C. that should give you better pedal feel and better modulation. Another thing that is hugly important is parking brake adjustment and purging all the air out for all First Generation W's. I really think the brakes are just fine for everyday use(providing they are updated with the best replacement parts and serviced correctly), The master is the problem....
                    The Powermaster is a pita but those are the best feeling brakes I have ever felt on a Wbody any year.. Hydro boost gives the best feeling and modulation imho. Braking action is immediate as opposed to vacuum assist where you have the buffer zone of no response.
                    Lorenzo
                    • nixtux
                      • Nov 2007
                      • 282
                      I replaced my pads last year with the cheapest pad I could find for my Cutlass and they have held up pretty good. It stopped fair under hard braking.
                      I've recently purchased new calipers/rotors and pads /w the best I could buy ($330.00) for everything including mounting brackets. I have yet to swap them in; I intend to do that once I get my motor/trans back in. I'm eager to see how much of a difference they'll make.
                      Has anyone had the plug for the ABS just break on them??? Cause mine did. When I get the calipers off I'm going to "fix" it but damn. It's weird cause both sides seem to have been "cut" and then "twisted" together /w electric tape. But the wires are cut at a angle /w all wires flush.
                      Has anyone else notices such /w the ABS plug?
                      • blackbombshell95
                        Kaiō-ken X 10
                        • Jun 2004
                        • 1386
                        Everyone stay on topic please. Or create a new one :P
                        • d.o.h.c
                          • Jun 2004
                          • 981
                          OK guys, I have bought the calipers, just need to get some rotors.
                          • d.o.h.c
                            • Jun 2004
                            • 981
                            Ok guys, I have a list of people looking to get these brackets made. Here is the list so far. I am only doing one run, so if you dont trust me, DONT put your name. Also if you dont have any money DONT put your name. I am putting out alot of money, so if your name is on the list, I will have a set made. When they are done I will send you a pick of them on and off the car to show that they do work.
                            1. dohc v6 - 2 sets, one 10.9 and one 11.25
                            2. blackbird21 - 1 Set 11.25
                            3.intern8tion9l - 1 set 10.9
                            4.Blackbombshell95 1 set of 11.25
                            5. Lakefxgp96 1 set of 11.25
                            6. GhrarhG 1 set of 10.9
                            7.
                            8.
                            9.
                            10.
                            • d.o.h.c
                              • Jun 2004
                              • 981
                              For all of you that dont visit w-body.com, here is what is up with the 13" brake upgrade.
