front strut curiousity
  • talon2swords
    • Dec 2007
    • 132
    I haven't examined them too closely, but when I pulled out the old front strut cartridges out of my 97 Lumina there was a lot of oil left in the outer casing cylinder. My manual pretty much told me to expect this.
    But upon further examination, there appears to be a valve or hole in the bottom of the old strut cartridges that may have allowed fluid in and out of the cartridge from the outer cylinder.
    I guess it was designed this way. But the KYB (Gr-2?) strut cartridge inserts i put in appeared to be sealed like a regular shock absorber.
    The ride seems a little stiffer with these new inserts, even though my old stuff was probably worn out (car is over 108K) I guess my question is, what is the better ride, the original equipment or KYBs?
    If I bought a new AC Delco complete assembly, are they made like the originals, with all this free-floating fluid in them?
  • HAULIN'cutlASS
    • Jun 2007
    • 13
    I've got a 98 cutlass with 140,000 on it. I switched to the KYB gr-2's as well and noticed an immediate change in ride stiffness. The KYB's are a bit stiffer than stock, but also handle A TON better! You'll notice a big difference in them during spirited driving out smooth twisty pavement...at least I could....
