sway bars? help needed
  • ProjectMM
    • Mar 2004
    • 170
    Waz up guy's, I'm lloking a doing a sway bar upgrade on my 2002 grandam gt 3.4L. but I'm wondering how big is big enough? is bigger better? Please help and if you know any manifuacters that would help! thanks
    Ps: I've been looking a the set offered from Speed built offered at PFYC.com and from manapart
    2002 Pontiac GrandAm GT1
    3400 v6
    TOG headers
    RSM 62MM T-body
    FFP underdrive pulley
    GRANATELLI MAF
    Ported upper intake
    MSD DIS 4 ignition box
    MSD Wires and coils (pending)
    Venom high flow fuel pump (pending)
  • StudlyCamaro
    • Nov 2003
    • 692
    i dont know anything about your specific application, but NO, BIGGER IS NOT BETTER, to a point bigger is better yes... however there is a point at which a bar becomes to big for the stock springs (or aftermarket for all that matters), if you just go around putting bigger bars on a car then you can very easily cause a car that will handle very bad (even dangerously) if you just mix and match suspen components..
    im running a 31 MM bar (stock was 17M) on the front of my car , and a stock 19MM bar on my camaro, people told me this was not a safe thing to do (they said that it was too big of a front bar for the small rear one), however i like the way it handles , the back end likes to creep around a bit, and after i did more research a lot of sutoXing people do this to help em get around tight turns.
    generally if a company offers a set then they will be safe to use together
    also dont forget to get a good set of bushings and endlinks, rubber ones will flex too much. IMO there isnt much of a point in upgrading bars unless you get a harger bushing, im running energysuspension componenets right now, but if i ever change them im gonna go with Prothane... they make quality mounts that are a bit softer than ES so you dont feel as much of the road , but they are still rather stiff
    hope that helped a little
    3.4L camaro some goodies
    • jeremy96gase
      • 93
      The ones that pfyc sells are the same diamiter as the stock ones, they are just sold insted of having the hole in the middle.
      The ones Mantapart has are actualy bigger but make sure to email them and ask how long it will take for them to ship.
