Rear suspension clunking over bumps
  • cutlass supreme FE3
    • Nov 2008
    • 225
    I have a 1988 Cutlass Supreme International with FE3 suspension.
    Last month I have replaced the rear shocks with some new Monroe sensa-tracs, new upper strut mounts and new boots.
    Now I hear a rear clunk on the driver's rear everytime I'm driving on uneven pavement or bumps.
    The rear swaybar links were still intact and not broken.
    Any help is appreciated.
  • 3100 MPFI
    • 1522
    check the springs pads for the rear monoleaf. They wear out over time, and can make clunking noises, as well as squeeking noises.
    Taylor
    1998 Lincoln Mark VIII
      • Nov 2008
      • 225
      would changing the spring pads be an easy job for a DIYer? I have seen pics of some special spring compressor for that monoleaf.
      • walterdude
        Destroyer Of ALL THINGS!!
        • Feb 2006
        • 265
        I've never used any special tools to remove the mono-leaf... Here's a txt file detailing what needs to be done... Seeing that FFP is no longer in business there shouldn't be a problem with me posting part the instructions for installing the coil-overs....
        Hope this is helpful,,,,
        Tom....
        • gpse3400
          • 1460
          Firstyou will want to get under the car and inspect the pads. the rubber is bonded to the fiberglass.. if you see broken down or no rubber you will want to fix this. There is a kit out there that will remedy this, it is called the spring helper kit. It is two polyurethane blocks that sit on the rear knuckles and the tips of the spring sit on these blocks. You can install them yourself by jacking up on the spring wit ha block of wood. Raise it enough so you can srape all th eold material off the spring tip and be able to slide the helper blocks on the knunckle. its pretty straight forward but will take a couple of hours. Cheaper than buying a new spring. Les time than removing the spring...besides I dont think GM sells the rubber pads anymore...You can get these from RockAuot.com or from GM.
          Lorenzo
          • 3100 MPFI
            • 1522
            I got mine from NAPA. They were about $25 a set.
            Taylor
            • 94GPGTP
              95 Grand Prix GTP
              • Apr 2007
              • 593
              i have the same problem but i just found it.. my car also squeaks all the time.. Do you know the 2 rods that are on each side of the spring? They go from the support crossmember to the knuckle assembly.. Well the rear rod on my car the bushing is like totaly gone and the wheel moves like the front as if you were checking for bad tie rod ends.. The whole rear wheel shakes and squeaks and vibrates b/c of that rear rod.. I just found this out 30 mins ago after i just put them helper spacer things in..
              You might want to check that.. its only a idea and a good way to point you..
              Now for me i have to have fun trying to get this from a local yard..
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              Drilled/Slotted Rotors
              White
              3" Magnaflow Catback
              90 Pontiac Turbo Grand Prix
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              230,000 mile Getrag 282
              Emissions Deleted
              Brand new Engine 1,000 Miles
              Fully Custom Built car
                • Nov 2008
                • 225
                you got a part number from napa?
                gm dealer says the spring rubber is not available.
                  • Nov 2008
                  • 225
                  no napa part number??
                  • gpse3400
                    • 1460
                    Try RockAuto.com. Moog K6544. Isolator pads for the rear spring. $17.14
                    Lorenzo
                    • SofaKingWeToddDid
                      • Jul 2009
                      • 785
                      this is old...
                      but clunking is probably a busted strut!! haha check where your struts connect with the mount (near the top) to see if the strut itself has been rubbing inside the wheel well. creaking and moaning is normal for those pads. but ive yet to hear a clunk
                      -also check where your exhaust it routed. my regal went over a rear crossmember instead of under and would ALWAYS hit it when the ass end of the car dropped from a bump. so very annoying. fix? i jammed some tire chunks in between the subframe and the tail pipe. safe? who cares. quiet? yes.
