Test ABS leads at wheel hubs
  • fastback4
    • Feb 2009
    • 175
    Need to know what the voltage should read testing the ABS leads going into the wheel hubs.......1997 monte carlo..I replaced the rear wheel hubs (new) and my ABS light remains on constantly..Regards......Tom
  • 93grandprixse
    • Aug 2005
    • 35
    technicly there shouldnt be any voltage there, but there may be a 5 volt reference depending on the type of sensor...
    the wheel bearing generates a weak ac current... try doing an AC voltage test on the wheel bearing and you will have better results...
    • fastback4
      • Feb 2009
      • 175
      Thank you i will.......Tom
