Z24 RWD conversion
  • montess408
    • May 2006
    • 391
    Z24 RWD conversion
    hey i have been thinking about covert my FWD Z24 to a RWD i know it's probley been talked about b4. but was wondering if there was a small rear that waould be close to the same width (maybe a rwd import or something) . i know that i will have to fab up some control arm's but was wondering if 2 lower control arm's and just the shocks would be enuf to hold it there? i am thinking that a panhard bar will be needed ?
    i am trying to figure out the rear first and then i will worry about the motor later i think i will be staying with my 3400 or go with a 3.4 camaro motor
    thanks
  • WS6LOVE
    coulda hada V8
    • Dec 2007
    • 54
    use a rear out of a chevette. its about the closest to the right size. thats what we're using in our rwd crx conversion
    sigpic<---SERIOUS cornering now
    300NAhp@the wheels....eventually
    http://www.cardomain.com/id/royal455<--new pics of the engine pull on the '94 firebird's page
    http://www.myspace.com/drfeelgood_80
      • 9190
      Kinda suprised I've never seen that car talked about before. Of course, the guy who build it, sold it back in 99 or so... Still an awesome build!
      • asylummotorsports
        Banned
        • Oct 2005
        • 649
        Anything and everything you will need.
          • 9190
          That was the site I was looking for but I couldn't find. Thanks for posting it!
            2WD S10 rear end
              2WD S10 rear end
              That or get a strong F body rear end and have it narrowed. If you don't want to use leaf springs you could use coil over shocks and 4 links. I've seen some 4x4 trucks that didn't use leaf springs anymore that used them.
              • latemodelnewbee
                • Jun 2007
                • 227
                http://www.youtube.com/watch?v=R_AsK2Jnq4o
                the 3rd and 4th gen F-body use the same axle as the regular S10 7.5" 10 bolt, the S10 with the towing package used the 8.5" 10 bolt which a pretty beefy axle. The 8.5" 10 bolt is just slightly weaker than the old 12 bolt axle that chevy used in all the old big block muscle cars from the 60's to the 70's and they are rated for about 650 hp with out modification, a lot more with better parts. Hot rod magazine built a chevette with a Cadillac 500 cubic inch V8 making 575hp and 650 lbs and they used a narrowed 8.5” 10 bolt from a 70 camaro and just did basic gear upgrade and added a posi
                68 El camino 454 speed muncie 3.90 posi 12 bolt,
                80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
                60 Impala 2 door hardtop L79-327 T56 4.11 posi.
                83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
                91 Z34 now has a hm284. and belly pan in the works
