Cutlass supreme a la four wheel steering now
  • cutlass supreme FE3
    • Nov 2008
    • 225
    well sister was too smart and rammed the rear end of the cutlass into the house wall.
    Here was the aftermath the rear now has 4 wheel steering.
    bent trailing arm so far
    rear stabilizer bar looks kinked too and needs replacement
    okay gurus what needs to be replaced?
    i'm amazed it only bent the trailing arm, i expected it to seperate from the mount on the frame...
      • Nov 2008
      • 225
      anyone know how the procedure is to remove the rear trailing arm?
        Well, look at it this way... Now is the time to move to GMPP (GM Performance Parts) trailing arms and an Addco swaybar
        • Scott205
          • Jun 2005
          • 265
          OUCH! hmmm, must live in the north..that be a lot of rust.. suprised everything held together!
          I am thinking time for you to do what I am doing... all 4 lateral arms and the two trailing links, straighten anything that needs straigtening, replace your sway bar and possibly the strut on the side she hit.
          2014 Chevy Cruise LT
          2000 Kawasaki ZX-6R Ninja Motorcycle
            • Nov 2008
            • 225
            well started to dismantle the parts that are obviously bent or broken and looks like just the trailing arm and rear lateral arm.
            problem i have is trying to get the bolt out from the center.
              • Nov 2008
              • 225
              where can i source these parts?
              • RedZMonte
                • Feb 2004
                • 1378
                What, did she try parking ACE VENTURA style??
                EEEEEE LIIIIIIIIKE A GLOVE!!!!
                LMAO!
                GMPP (GM Perfromance Parts.... OEM performance parts) control arms for a 1996-2003 Grand prix is available threw your local dealer or ZZPerformance.com, GMpartsdirect.com. its in the GM Performance Parts catolog. most of your performance sites like ZZP for the newer GTP's will have them. its the same part for our cars as the newer "W-Body's". as for lateral links... OEM, BMR (tubular, polly, adjustable) , or junkyard.
                Shane "RedZMonte"
                1992 Lumina Z34-VIRGIN (RIP)
                1992 L67 Lumina Z34 (SOLD)
                1990 Turbo Grand Prix (SOLD)
                  i would PAY to see someone do that perfectly, i don't care what vehicle.
                    • Nov 2008
                    • 225
                    how do you get the last bolt out in the middle where the leaf spring is??
                      • Nov 2008
                      • 225
                      I really need to know if there is any tricks to get this bolt out.
                      thanks
                      • WrathOfSocrus
                        • Jan 2008
                        • 318
                        Page 10-12 of the Haynes manual 12.11 says,
                        "On 1988 and 1989 models mark the position of the toe adjusting cam to the crossmember. Remove the toe adjusting cam and push the bolt through far enough to allow the rod to be removed.On some models it may be necessary to lower the fuel tank for access to the front rod bolt."
                        I believe that means the rear lateral links can be removed easily but the for the front links you would have to either drop the gas tank or drop the entire crossmember to get the bolts out.
                          • Nov 2008
                          • 225
                          Hi,
                          I lost my haynes manual and the nut is removed but the bolt is not coming out as it is hitting the fibreglass leaf spring. I just need to remove the rear lateral link.
                          As for lowering the gas tank it is not close enough to cause any problems
                          just take a look at the picture i took,
                            • Nov 2008
                            • 225
                            help???
                              • 9190
                              If its hitting the leaf spring, then probably the only solution is to remove the leaf spring.
