Bolt Pattern
  • GTP091
    • Jun 2005
    • 232
    Bolt Pattern
    Do you guys know what the bolt pattern is on a 91 GTP? I found a good deal on some boss rims but not sure if they will fit. 5 X 100mm??
    • 9191
    A W-body is most likely 5x115mm.
      i think you're either right, or close. it might have an odd bolt-spacing, i can't remember, like 114.5mm or something close to it...
      the info is on w-body, i know that.
        • 9191
        The odd spacing would be 114.3mm
        • RedZMonte
          • Feb 2004
          • 1378
          5x115 38mm offset 16"x6.5" or 16"x8" If you have the cross lace wheels.
          Shane "RedZMonte"
          1992 Lumina Z34-VIRGIN (RIP)
          1992 L67 Lumina Z34 (SOLD)
          1990 Turbo Grand Prix (SOLD)
          • GTP091
            • Jun 2005
            • 232
            I found it after i posted this is the correct answer> thanks guys!
            • RedZMonte
              • Feb 2004
              • 1378
              5x114.3 will fit w/ a centric hub ring but not ideal.. anything smaller or bigger will not work.
              S
              Shane "RedZMonte"
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                Ben had his studs break off with 114.3 rims. 114.3 are commonly used on mustangs i think.
                5 x 115 for wbodies.
                02 GTP - 90* > Failboat
                www.blackbombshell95.com
                • GTP091
                  • Jun 2005
                  • 232
                  I don't think I would risk it either. I'm not sure what a hub ring looks like but seems kinda hack.
                  • RedZMonte
                    • Feb 2004
                    • 1378
                    its not ideal but it works... it just centers the wheel to the hub so that it is not offcenter causing vibrations. it is only .7mm off so it does technically pull the studs in to the center a tiny bit.. Again not ideal but will work.. if there is a 5x115 option for your wheel of choice definatly get the correct bolt pattern.
                    5x114.3=5x4.5 which is a common RWD bolt pattern.. alot of GP guys run the mustang bullet wheels.
                    Shane "RedZMonte"
                    • HayesPerformance
                      • 783
                      what is the difference between the first and second generation w-body for off-set and bolt pattern?
                      1991 Grand Prix STE
                      3.4 DOHC
                      1 of 792 Produced
                      Extensive Mods Done
                      1991 Lumina Z34
                      3.4 DOHC
                      Getrag 284 5spd
                      1 of 30
                        from w-body.com
                        First Gen W-body
                        1988-1997 Oldsmobile, 1988-1996 Buick Regal, 1990-1994 Chevy Lumina, 1988-1996 Ponitac Grand Prix
                        16x6.5 Rim Diameter/Width
                        5x115 Bolt pattern
                        +38mm Offset
                        94-96 Pontiac 5-star 16x7, offset is also +25mm ( All B4U wheels are +25mm )
                        1989-1990 Pontiac Grand Prix TGP crosslace* wheels are:
                        16x8 Rims Diameter/Width
                        5x115 Bolt pattern
                        25mm Offset
                        *Crosslace rims were 16 x 8 until 1996. From 1997 and up, they became 16 x 6.5
                        Generation 1.5 W-Body
                        1995-1999 Chevy Monte Carlo, 1995-1999 Chevy Lumina
                        16 x 6.5 Rim Diameter/Width
                        5x115 Bolt Pattern
                        +38mm Offset/Backspacing
                        Second Gen W-Body
                        1997+ Grand Prix's, Impala, 2000+ Monte, Olds Intreuge, 1997+ Regals
                        5x115 Bolt pattern
                        +52mm Offset
