1995 Grand Am rotor options
  • WS6FirebirdTA00
    • Dec 2009
    • 18
    Hey guys,
    I have a 1995 Grand Am and need some decent rotors for it. Unfortunately, I am pretty harsh on the brakes and I have a lot of surface cracks on my current rotors. On my Trans Am I had issues with warping until I put a decent set of slotted and drilled rotors on there. Now whether or not it was the quality of the part or the slots/drills that help is debatable, but I was trying to find a decent pair of rotors for the Grand Am too. Any good manufacturers out there to look for? I can find a lot, but I want something that is proven and I have limited knowledge on these parts for the Grand Am.
    Thanks
    Shop R1 Concepts performance brake parts, brake pads, rotors, kits and more. R1 Concepts is the leading manufacturer of braking systems for all vehicles
    i would go for slotted, but not drilled... heat and stress can cause microfractures around the drilled holes and REALLY ruin your day...
    • WS6FirebirdTA00
      • Dec 2009
      • 18
      Thanks for the link.
      • Azrael
        Accelerating uphill in OD
        • Apr 2005
        • 763
        I tried the non-cryo treated powerslots but they disintegrated from corrosion after a few years. I'm currently on a set of EBC USR rotors with decent results but it hasn't been a year since they were installed. 92-98 Grand Ams also share the same brakes as 95-03 Sunfires and Cavaliers.
        1995 Grand Am SE
        • Guest
          I will never run crossdrilled or slotted rotors, unless they are Wilwoods (or similar) on a race car, and race car only.
          The best upgrade I did to my Malibu, was to change to Impala front brakes and Alero rear disc brakes.
          Unfortunatly, I think the '95 Grand Am is closer to the J-body in brakes than the later N-body, so a similar upgrade would not be as easy as it was for me.
          I would suggest using good quality rotors, and pads, but not slotted or drilled, I found I had better braking with a stock brake rotor over the slotted counterparts, on my J-body.
