I think I need a track alignment...
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    did this at an auto cross today. put 2 more runs on the tire after this pic lol. I went into a corner way too fast and turned too sharp, basically slid but I dont think I hit the cones
    what specs would you use? the car isnt daily driven anymore, just driven to the races mostly. It also sees the drag strip
  • mfuller
    Mr. Common Sense
    • Nov 2003
    • 374
    Kinda depends on what tires you will be using.
    Road-race or autocross tires will want more negative camber than you can safely use on a street tire.
    Also, what works well for auto-x won't work that well for drag racing.
    Matt
    • Alxsmt
      that one guy
      • Feb 2007
      • 725
      I just run durezza star specs. "ultra high performance" street tires but not R compound.. I use those for street and autox. then hoosier drag radials for drag. I have read a little negetive camber helps with drag racing because when the front lifts up it levels the tires out, but I have koni yellows and there pretty solid so im not sure how much the front lifts up yet, havent gotten a video yet
      • mfuller
        Mr. Common Sense
        • Nov 2003
        • 374
        I'm familiar with the Z1 Star Specs.....great tire for the price, but I've had issues with them chunking up.
        I run 3 degrees of negative camber up front with 1/8" of toe-out. In back, 2 degrees of negative camber with zero toe.
        Matt
        • Alxsmt
          that one guy
          • Feb 2007
          • 725
          what tires do you run? is your car independient rear suspension? I dont think I have any adjustment in the rear.
          • mfuller
            Mr. Common Sense
            • Nov 2003
            • 374
            Right now I'm on a set of Bridgestone Potenza RE-01Rs. Still a street tire, but similar in design and intended use to the Dunlops.
            Yes, I have independent rear suspension.
            I'm nowhere near fast enough to need something like a Hoosier R6.
            Matt
            • Cobra
              Autocrosser
              • Dec 2006
              • 8
              I ran the RE-01Rs on my old Street Touring Saturn SC2 and they were the hot tire of the class. Great tires for such a light car.
              I've got a set of Victoracers for the Z24 for this coming season, basically DOT approved slicks (50 treadwear). Planning on running at least 2 degrees neg camber up front. Can't do anything in back really without basically rebuilding the rear end.
              If I were gonna be running in a street tire class, I'd probably look at picking up some Kumho Ecsta XS. Those tires seem to love thrashings from "heavier" cars without much complaint.
              91 Z24 - Whitelightning2 - '00 3400, top end P&P by Superdave, 3500 manifolds, 2 1/4" mandrel bent exhaust with Hooker Aerochamber F-body crossflow - SCCA Solo Street Modified FWD #16
              2008 Cobalt LT Sedan - Slow and stock - Part-time DD
              • Alxsmt
                that one guy
                • Feb 2007
                • 725
                how can you not be fast enough for an r6? they make you faster! I would love to have a set, Im already keeping up with some modded subys with slicks on my dunlops
                cobra - whats your suspension setup?
                • mfuller
                  Mr. Common Sense
                  • Nov 2003
                  • 374
                  The motor's holding me back at this point, not the tires. Hopefully that will be remedied soon.
                  Matt
                  • Cobra
                    Autocrosser
                    • Dec 2006
                    • 8
                    Current suspension is what it had when I got it from Dave - Sprint springs, Gabriel shocks/struts, stock sway bars. Plan is Konis all around with the Sprints (have the rears, ordering 3rd gen J front inserts soon), Beretta rear axle with internal and external bar with the Chrysler rear disc swap. Hope to have all this done in the next 3-4 months.
                    I only plan to AutoX this car for a year or two. I'm looking for a dedicated track rat to build after I get moved into a house down here.
                    • Alxsmt
                      that one guy
                      • Feb 2007
                      • 725
                      ah, I didnt know dave sold his car. I have konis all around with eibachs. there amazing. seems to handle best at full soft (which is 50x stiffer than the kyb gr2/gas a just).
                      • robert 1980
                        • Aug 2009
                        • 302
                        Hey alex what size rims do you have your slicks monted too??I was going to get a set of mickey thompson slicks part#3015.They are the only ones i know would work for sure with my 15in rims.Wow 50x stiffer thats crazy i know my eibach and kyb combo is fairly stiff.
                        • Cobra
                          Autocrosser
                          • Dec 2006
                          • 8
                          I bought his Z back in October.
                          Eager to see how well this thing does with the Konis on it. Hitting my first event the first weekend in April.
                          • Alxsmt
                            that one guy
                            • Feb 2007
                            • 725
                            my drag radials are mounted on an extra pair of GTZ wheels. 16x7 i think. well maybe not 50% stiffer but its a HUGE difference. when there on full stiff I cant move the car when I jump on it.
                            • robert 1980
                              • Aug 2009
                              • 302
                              But you don't remember the part number for them??I could only find measurements from m/t on there site.Then i emailed them and they confirmed it would work.Did you have a fun weekend get a lot of racing done??
