1996 Grand Prix SE 3100 SFI
Getrag-282 swap
After the manual swap, the master cylinder interferes with the shifter selector (left/right spring loaded). Mounted normally it makes shifting into 5th and R far too stiff and difficult to be safe on the trans.
When I loosen the Master Cylinder to the Brake Booster and lift it up about 1/4" it clears the shifter and I can row through the gears normally.
Right now the Master Cylinder is shimmed where it meets the Brake Booster. The pedal still travels properly. But I can not leave it that way.
I need to find a master cylinder that has more clearance on the bottom of the assembly. Does not need to be ABS. In fact, Jeff mentioned a non-ABS master cylinder should fix the issue.
A few things to note:
- Engine and trans mounts are in proper and the subframe has not be raised.
- Using the proper mounts for the W-Body Manual.
- Original brake booster w/ no modifications
- Transmission shifting levers are on properly
I'm open for options, suggestions, etc.
Getrag-282 swap
