Caster and Camber
  • Crede17
    • Jul 2004
    • 7
    Caster and Camber
    Today I had the alignment done on my car. The caster and camber was adjusted. My car is a 94' olds cutlass supreme. Driving home I was getting off the highway and hit the brakes. The car slammed to a stop pulling to the left very hard. I got out of my car and the top left caliper bolt was off and the caliper was shoved into the rim. Is the caster and camber adjustable on this car? And if so, how because I'm not familiar with it. Does the brake caliper have to come off to adjust caster or camber in any way? P.S. this has cartridge style front struts. Help!
  • gpse3400
    • 1460
    Technically caster and camber isn't adjustable on the front of early W cars. Just the toe. IF they really had to make an adjustment, they would have to either remove the upper black plate and drill out the 3 strut bosses or loosen the lower frame and reset it. these procedure have nothing to do with the brakes.
    The rear camber can be adjusted. rear toe isn't adjustable after '91 I beleive.
    Lorenzo
    • quantum110
      • 175
      Rear toe is adjustable on all W-bodies...
      67 Olds Cutlass 2bbl 330 w/ 2 speed Jetaway
      • gpse3400
        • 1460
        Nice! That retrofit kit must be new then. Because later on they weren't adjustable. I know my '93 isn't but my late '89 Pontiac was.
        Lorenzo
        • Juglenaut
          • 1130
          My Euro had stock adjustible toe on the rear.
          I am back
          Mechanical/Service Technican
