Rear brake conversion
  • DEI37
    • Jan 2004
    • 516
    I already know that if it was possible, I'd lose the park brake, but, is it possible to install the complete front brake system from a '97 CS on to the rear axle? Using the thicker and larger rotors with the dual piston calipers is just so tempting. Can it be done?
  • DEI37
    • Jan 2004
    • 516
    RE: Rear brake conversion
    Anyone?
    • blk92z34getrag
      • 515
      Yes it can be done. As I recall the swap is pretty straight forward. I'm also thinking about doing the swap. To attach the parking brake I remember someone using about 50 washers... I don't remember how though. I think I saw the picture / how to on GMForums.
      --Rob
      • DEI37
        • Jan 2004
        • 516
        I don't think you can possibly keep the parking brake using the front calipers on the rear. I'd like to be wrong, but I just don't envision that working.
        • Rhedalert
          Dr. Feelgood
          • 1574
          you're out of your mind. Off the top of my head, I'm sure the master cylinder would be PISSED. 2nd off, if you were to somehow get them to work properly, your rears will lock up a bit sooner than the fronts.
          Brian
          3400 SFI V6, 4T60e
          • DEI37
            • Jan 2004
            • 516
            OK...you could have said that a WHOLE LOT nicer with that first sentence. It was a question, and an honest one at that. Question is, why would the rears lock up sooner than the fronts? They still wouldn't be given any more real bias, I wouldn't think. Don't know why the master cylinder would care, either.
            • Rhedalert
              Dr. Feelgood
              • 1574
              Well to be honest, our master cylinders are small enough and could stand to be a bit bigger. Look at a G-body master, compared to ours, and those cars weigh about the same as a W. The G's have much better, more sensitive brakes, no comparison, and they have a SMALL booster. Furthermore I've never seen equal brakes at all 4 corners on a FWD. To say the least the braking system would be quite out of balance. If you got a bigger master, put bigger hydraulic lines to go to the rears (like 5/16 instead of 3/16 or whatever they put back there) got some monster size brakes for the fronts, and can find a way to "tune" the brakes such that the rears won't prematurely lock in the rain, for example, then you might stand a chance. But this isn't just a bolt-in swap like the 94+ style rears.
              Vented, dual piston rears are not needed for any of our cars. The rear brakes in a car with 70% of its weight over the front axle do not do much work. They'll just lock up and thats it.
              Brian
              3400 SFI V6, 4T60e
              • DEI37
                • Jan 2004
                • 516
                OK. Gotcha. That all makes sense. I'm not very well educated on braking systems, and how it all works, just that bigger and heavier, is generally better. Thought I could make that apply to the rear as well.
                • blk92z34getrag
                  • 515
                  Oh wow I read that post wrong. I didn't notice the FRONT caliper part... Only got like 3.5 hours of sleep... was up 6am till 4am the next day... been kinda woozy all day.
                  No you can't keep the parking brake, front calipers don't have the proper hardware. However I'm sure it can be done. You just need mounting brackets for the calipers, the rotors should slip right on. I don't know how you would do the mounting brackets for the calipers though. Probably something custom.
                  I don't know if it would be worth the money or the trouble though.
                  --Rob
