94 grand am gt death wobble
  • bremen242
    • Mar 2004
    • 27
    I've balanced tires (and rotated), replaced balljoints, replaced lower control arm bushings, the tierods are tight, and yet I am still getting a bad shake at 60mph. sometimes, it is better or worse, sometime when I'm going real slow (like ~5-10mph) it'll move the steering wheel back and forth like 2".
    could my rack and pinion be loose or going bad?? what are the symptoms?
    also, my front tires have a weird wear patten on the outside edge, like the toe in is real whacked, except that the wear pattern isn't constant, some spots are worn more than others.
    I figure it needs an alignment, but I don't think that will fix my shimmy.
    any ideas?
    \'94 grand am gt
  • DEI37
    • Jan 2004
    • 516
    RE: 94 grand am gt death wobble
    I'd get it aligned, and get new tires. Sounds like a belt may have either shifted, or separated in one or more of the tires.
    • firechiken
      • Feb 2004
      • 557
      "death wobble" Yeah sounds like the tires are f'd up.
      • bremen242
        • Mar 2004
        • 27
        I've probably going to try the tires. however, I have had these tires on the back with no vibs in the back, only in the steering wheel.
        \'94 grand am gt
        • geldartb
          The Situation
          • May 2004
          • 1994
          my z26 did that nasty skake when the wheel bearing went crappy
          99 Grand Am GT
          1357 cam 227 233 .050 dur
          515 515 lift 112 lsa
