Trailing Arms?
  • blk92z34getrag
    • 515
    Trailing Arms?
    I think I remember reading a long time ago that there was some after market replacement for our rear trailing arms? One of mine is bent and I need a new one, so I figured I'd replace both with better aftermarket ones. What was the application this was off of? I seem to remember hearing a newer Grand Prix... but I don't remember. Also part number / where I could find it would be helpful too.
    Also, I need to replace my front bushings (control arms and probably sway bar bushing, haven't seen them recently), what are my choices for aftermarket other than RSM? I want Polyurethane bushings.
    --Rob
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    RE: Trailing Arms?
    97-03 grand prix trailing arms. don't know the part #... bmr trailing arms at clubgpstore.com those are even better and more expensive.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    • AWeb80
      W-body RSTB Maker
      • Feb 2004
      • 392
      RE: Trailing Arms?
      go to gmpartsdirect.com Part # 12498649
      they are like $30
      • blk92z34getrag
        • 515
        Hey thanks a lot. I'll be picking up a pair of those pretty soon.
        --Rob
        • blk92z34getrag
          • 515
          Also, do they make a big difference? I don't plan on going to FFP coil-overs... mainly because they're too expensive but I don't really want to lower the rear of my car. I'm going to stick fatter tires on the back (255/45-17 rears, 245/45-17 fronts) because my car oversteers when you whip it through an S turn... which is really fun in a FWD car but I'd rather it be more neutral.
          --Rob
          • AWeb80
            W-body RSTB Maker
            • Feb 2004
            • 392
            I'm sure they make a difference....i couldn't tell alot becaue i already had on wider tires, FFP's, and the ADDCO bar....just look at the design when you get them.....way better than stock.
            • pepsi_coke
              • 288
              Re: RE: Trailing Arms?
              they are like $30
              For a pair or one ?
              New member of 200,000 mile club as of May 16, 2005
              • AWeb80
                W-body RSTB Maker
                • Feb 2004
                • 392
                they are like $30
                For a pair or one ?
                Pair.
                • blk92z34getrag
                  • 515
                  I was going to ask the same question... that's awesome! So cheap! I'm gonna be all over those. Putting in my order right now as a matter of fact.
                  --Rob
