Hi to all,
I have a buick regal that had always been with bad brakes, so days ago I bought 4 new original delco brake pads (semi-metallic)
The problem is that now the front brakes are too tight and the front wheels get high temperature.
I don't know if the problem is a clogged caliper, brake piston or too wide brake pads.
Also I had a problem with one rear wheel hub assembly, so I bought a new one (expensive one), but the new part has the same problem after only 10 miles! is like a loosen bearing (the whole hub moves up and down with ease).
Thanks for any suggestions.
