carr still pulls to the left....aaaaaaaaaaaaaaaaaaah!!!!!!
  • gboogie99
    they still can't catch me
    • Nov 2005
    • 348
    okay a few months ago my olds started pulling to the left. So I:
    1. got an alignment
    2. replaced both front calipers and pads and bled system
    3. replaced transmission mount and got an alignment
    4. replaced tires, then got new wheels & tires got an alignment
    5. pulled and checked rear drums...nothing unusual, just dirty
    6. replaced driver side wheel cylinder and bled system
    what the hell is left?
    i thought it might be a ball joint or tie rod, even a strut mount...
    somebody help!
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Well I was going to say tires right away. But you have replaced them.
    Did you get all 4 wheels aligned? You may have a bad thrust angle problem on the back if it was ever worked on. It uses a twist beam on the back right?
    • torq455
      If I only had money!!!
      • Dec 2003
      • 1615
      Make sure your tire psi are the same. Swap the left and right front tires.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
      • gboogie99
        • Nov 2005
        • 348
        well, i got performance tires and they only rotate one way...
        I think all i got left now is strut mounts. I plan on replacing a cv axle soon because now that is making noise
        • Rhedalert
          Dr. Feelgood
          • 1574
          are the springs at the same ride height when compared to the opposite one on the same axle? Meaning say your left front spring sags more than your right front.
          Brian
          3400 SFI V6, 4T60e
          • gboogie99
            • Nov 2005
            • 348
            thats a good question because i did start noticing a lean on one side of the car recently. I was gonna replace the springs when i pulled the struts anyway, so that might do the trick.
            • Rhedalert
              Dr. Feelgood
              • 1574
              hopefully. My left front sits a slight bit lower than the right front, and I have a pull to the left. It's actually quite annoying, and the only thing that bothers me about this car. I had an alignment done and it didn't help, and the struts and tires are new. I'm going to use a spring helper on the LF just to see if that corrects it.
              Brian
              3400 SFI V6, 4T60e
              • gboogie99
                • Nov 2005
                • 348
                hey good idea, i can get those for about 4 bux
