Spacers on a GTP
  • bve32k
    3.4 DOHC FTW
    • Jun 2005
    • 475
    Spacers on a GTP
    I am looking at 1/2" spacers and checking to see if the inside diameter would fit on my 95 GTP. The inside diameter of the spacers I found are 3.55". Will these fit on my hubs on my car? In the pic below I believe I am looking for G. Am I correct?
    A= 5.689 in.; B= 4.528 in.; (C) BOLT SIZE (QTY) M12X1.5 (5); D= 2.761 in.; E= 2.781 in.; F= 1.772 in.; G= 3.583 in.; (H) BOLT CIRCLE DIA= 5.748 in.; (I) BOLT HOLE SIZE (QTY)= M10X1.50 (4); (J) SPLINE COUNT= 33; (K) FLANGE SHAPE= RECTANGULAR; w/ABS
  • RacerX11
    • 1060
    What are you trying to space out? Using 'G', you will be spacing the hub/bearing assembly away fromt he knuckle. This would require longer CV axles, assuming the outboard joint would even clear the knuckle.
    If you are trying to space the wheel out fromt he hub, you should be using dimension 'E'.
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
    • bve32k
      3.4 DOHC FTW
      • Jun 2005
      • 475
      I am getting rims soon and would like to space the rims a 1/2" out. I found out the rims are not hubcentric though so I have to have some custom spacers made so everything would be safe.
      I may have found someone to make them..I just have to get the dimensions and give them to him.
