4t45 in a 2003 malibu?
  • rluck9277
    Me and My Grandma Car
    • Jun 2006
    • 32
    I have a chance to pick up a 4t45 out of a 2003 grand am gt with 28,000 miles for $300. I know a 3400 drops right in for a 3100, but i was wondering if the trans missions will? I was think anout the extra torque the 45 can handle and also the 3.29 axle over my 3.05, would I have to do anything other then ahve the PCM reprogrammed for the different gear? I already have a custom tuned PCM from milzy.
    http://www.cardomain.com/ride/2367486/1
    • 9190
    Yes, it should be a direct swap. I have heard of a couple of GA SE guys doing it.
    • rluck9277
      • Jun 2006
      • 32
      cool, i thought so but wasn't sure, thanks
      • prophiseer
        Blaspheming Heretic
        • Jun 2006
        • 354
        yeah it'll swap without issue. Both the T40 and T45 cases are exactly the same, difference is all internal; mount locations should even be the same between the two, if not the brackets from your T40 will bolt right onto the T45. You'll need the PCM flashed, though; T45 runs a bit higher line pressures and shift points are a touch higher.
        N-body enthusiast:
        {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
        {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
        Current Project:
        {'90 Chevrolet C1500 Sport 350TBI}
