Getrag 282 Clutch options????
  • Invasion1
    • 74
    Hey guys
    well my 5-speed tranny has been serviced and is needing a GOOD clutch....
    any recomendations???
    I heard Centerforce is crap.......
    what have you other 5-speed Swap guys used?? and had sucess??
    its mating up to a 3.1 turbo engine FYI
    any input is welcome
  • v6h.o.
    • 1418
    Bully Clutches, you can get them for the best price through Jbody Performance.
    Bully Racing, Performance and Competition Clutch, home of the best performance clutch on the market today
    if its for a 282 trans, just make sure its the same year as your when searching for the listing on JBP, due to i know it only lists them as "cavalier" clutches. they will be the same clutch no matter what car line, just as long as its for the proper year of trans.
    Colin
    • Invasion1
      • 74
      i have looked at Jbodyperformance.com have you delt with them before??
      there in Toronto which if good for me... :P
      I was looking at getting some other stuff from them also but didn't know anything about them so....
      anyone out there have info on Jbodyperformance.com?????
      thanks
      Dave
      • Cliff8928
        • 532
        I've had good luck with my Clutchmasters Stage 3 ( http://www.clutchmasters.com )
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
        • Erich
          masterbater mechanic
          • 67
          Hey David!
          I would recommend a Spec Stage II over a Clutchmasters Stage III. I have a Clutchmasters one one car and putting Spec's on the others.
          1990 6000 SE AWD 3.1 "The Goose"
          1995 Beretta Z26
          1996 Beretta Z25 w/3500
          1999 GAGT
          • Invasion1
            • 74
            hey Erich
            didn't know you were on here too.....
            im still shopping for a clutch though.. im kinda waiting till my tranny is done being serviced.....
            do you have a web link to that clutch site that you reccomend???
            Spec is the brand name they go by
            or are you meaning a stage II Clutchmasters rather than a Stage III Clutchmasters unit???
            thanks
            Dave
            • Invasion1
              • 74
              ah ha
              found it all by myself......
              even have a aluminum Flywheel for the Grand Prix Application....
              sweet i will read up on them
              thanks again Erich
              • RebelGT
                • 642
                400 bux for the flywheel, wonder how much it weighs.
                26+6=1
                • RidgeRunner
                  • 971
                  I wonder why they don't list it in some other 60v6 applications.
                  60v6's original Jon M.
                  • Erich
                    • 67
                    I am ordering the Spec Stage III which is ceramic for a 5spd 3400 car we are putting together.
                    The Stage II is kevlar like the Clutchmasters Stage III. I have a Clutchmasters stage III "kevlar" in my 1990 Quad 4 GTZ and its a godd clutch.
                    The Spec clutches have been getting some great reviews by the Fiero guys.
                    1995 Beretta Z26
                    1999 GAGT
                    • GPXSS
                      • 588
                      Fiero w/ SPEC stageII representin'
                      I modify stuff
                      • Invasion1
                        • 74
                        reviews?????
                        I just got the Stage III and Aluminum Flywheel
                        waiting to install as we speak
                        • robby1870
                          Squaddoosh
                          • 584
                          how much does the Aluminum flywheel weigh and the stock one? Got a scale Dave?
                          Robby Whitesell
                          2006 Pontiac G6 GT
                          1985 Toyota Pickup DLX
                          • Invasion1
                            • 74
                            The Aluminum one is about 7.5 lbs
                            and the Heavy Stocker is 16 lbs...............
                            the whole stock set-up I had weighed a total of almost 30 lbs......
                            now the new SPEC set-up is much less....around 20.5 lbs on my scale anyway......
                            cheers
                            Dave
                            • robby1870
                              Squaddoosh
                              • 584
                              Yeah....pretty noticeable difference. That TGP should rev up nicely......at the expense of some low end
                              Robby Whitesell
                              2006 Pontiac G6 GT
