Manual Transmission question/problems Getrag 284
  • xanth
    • Dec 2003
    • 4
    For all those familiar with a 284, I'm having a little problem with mine. When it sits for any time, say over night, the clutch system looses all hydraulics. After pumping it about 30 - 40 times, it will work again and is drivable.
    Sounds like a small leak to me, I have looked over everything real good, and the only part with any fluid on it is the (i dont know what these parts are called) part right before the actuator that bolts to the transmission. The manual calls it the "canister". Is this thing the slave cylinder? I can't find where its leaking at, but it has fluid all over it (not a whole lot, but it has eaten the paint off), and down the hydraulic tube to the actuator.
    Any comments or help is greatly appreciated. Thanks!
    98 BlaZeR2
    91 GTP 5/Speed
    96 RF900R
  • brian89gp
    • 554
    That round thing is the accumulator, I guss it is possible for it to spring a leak. That is what it sounds like too, a leak or possibly air in the system.
    • xanth
      • Dec 2003
      • 4
      Thanks! So what/where is the slave cylinder.
      98 BlaZeR2
      91 GTP 5/Speed
      96 RF900R
      • 5speedz34
        • 301
        The slave cylinder is the part that bolts to the transmission.
        1992 Lumina Z34 | 3.4L 207ci DOHC 60º V6; Getrag 284 |
        1994 Pontiac Grand Prix GTP | 3.4L 207ci DOHC 60º V6; Hydra-Matic 4T60E |
        • Anonymous
          When my car is cold, overnight freezing, I can't move the shifter side to side. Only 1st and 2nd work. But once the cabin warms up, it works fine.. Only did this since the rebuild. Oh well, I got over it.
          • brian89gp
            • 554
            Probably twisted your cables some, I did the same thing on mine.
            The end of the hose piece is the slave cylinder, it is attached to the accumulator by about 4-6" of hose, the accumulator is connected to the master cylinder by 24" or so of hose.
            • Juglenaut
              • Dec 2003
              • 1130
              so the real question is are you going to try and find a used slave or get a new one???
              Check the line that goes into the Master slave. I might need a need Master soon since the last time I checked the pipe it had a spot that was almost worn thru.
              I had the exact thing happen to mine, and it turned out that the base of the accumulator was leaking and so was the lock pin joint.
              I took the slave out and found to amazement that the rod bushing was bad and the retainers were gone!!! That explained the hard shifting in all gears. The slave had a lot of side play even when rebuilt with a decent used retainer and bushing so I got a new one.
              It good to get some lube under there I spray WD-40 occasionally to inhibit rust on the links and bracket.
              I am back
              Mechanical/Service Technican
              • xanth
                • Dec 2003
                • 4
                Did you end up getting a new accumulator? If you did, where did you get it from?
                98 BlaZeR2
                91 GTP 5/Speed
                96 RF900R
