Grand prix 4t60e Transmission swap?
  • TravisaKaBiggie
    • Jun 2007
    • 4
    Can I put a 1995 grand prix 4t60e into a 1996 grand prix? My transmission just went out and my brother is ripping his out of his 95 within two weeks and he offered it to me, so we want to know if it will work in my 96, or if there is something we have to do for it to work. Thanks
  • DEI37
    • Jan 2004
    • 516
    It should. One thing that might be an issue could be gearing, depending on which engine was in the car. Your engine choices are a 3100 (most likely) or a 3.4 DOHC V6.
    • TravisaKaBiggie
      • Jun 2007
      • 4
      oh sorry, both of our engines are 3.1 v6s
      • TravisaKaBiggie
        • Jun 2007
        • 4
        my brother was saying something about the electrical between the two. I need certainty that a 95 4t60e will work in a 96, same engines. just different computers.
          • 9185
          Different computers shouldn't matter. Best bet would be to find wiring diagrams for both cars and verify the tranny wiring is the same. It should be, as most of the changes in electronics, from what I have seen, happened between 93-95. You may also be able to do a search on car-part.com to see if they are interchangable.
          For wiring diagrams, www.alldatadiy.com is usually the best source, although it'll cost you $35 to get 1-yr subscriptions for both cars. But at least you'll basically have a GM Service Manual for your use for the next year for both cars.
          • Chris88CL
            Moderator
            • 212
            If the 95 car isnt OBDII you will have to swap a couple sensors over on the tranny but i shouldnt be a problem.
            I put a 96 Grand Am 4t60-e into my 95 Beretta Z26 and had to swap over a couple sensors and should have swapped over the gear for the VSS. Something about needing a 29 tooth instead of the 31 or whatever came with the GA tranny. My speedometer is off. At the time I didnt care enough to crack open the case. Not sure if thats an OBDII change or just a difference between the vehicle models that caused that issue for me. Just something to be aware of.
            Other than that I had no issues, so you should be fine.
              95 to 96 grand prix, nothing has to be changed.
              The ONLY sensor you would EVER have to swap and is probably vehicle specific would be the tone ring pickup speed sensor, and thats ONLY if the harness plug differs, which I think they do not untill you get into the newer years.
              you wont have to touch your tone ring though since its the same car type.
              Other than that there is no OBDI to OBDII differences... For example I'm running a 94 trans on my OBDII swapped Beretta.
              • TravisaKaBiggie
                • Jun 2007
                • 4
                thanks for the replies.
                • Rhedalert
                  Dr. Feelgood
                  • 1574
                  there IS one difference, and that's the gear indicator/ safety switch on top of the tranny. Just transfer it over. I have a '97 tranny in my '95 that was the only difference.
                  Brian
                  3400 SFI V6, 4T60e
                  • mdizzy
                    • Nov 2007
                    • 1
                    to the guy with the pic of the sick 3100----where, how, how much, were all the parts for that to come together---I have been searching high n low for performance part and i've only found a few sites that offer high priced parts that i can basically have a machine shop take care of for me---ported heads for example---if you can get back to me at mduffany92@hotmail
