95 4t60e to 96 4t60e, reluctor ring change, easy?
  • tr6lover
    • Jul 2007
    • 1
    Hello all!
    I just bought a 95 Olds Ciera with the 3.1 and 4t60e trans, and of course the trans is junk...My friend owns a towing business and has a good similiar trans from a 1996 gm product out back that he said i can have. I researched both transmission and found out that his trans is from a 96 olds ciera 3.1 also, has the same drive ratio and all, but has a different tooth count reluctor ring than mine, 31 vs. 30. Are they hard to change or should i just buy the correct transmission for my car? My trans is a 615PAW and his is a 616PAW model. Any help would be GREATLY appreciated for life!..
    Thanks
    Paul
    • 9189
    It should be a relatively easy change since the nose of the 60E can be separated from the case. And then the wheel should be right in that area.
    • sharkey
      • Jun 2004
      • 2061
      if your diff from your tranny is in good shape, id just swap the whole diff over.
