I have a 95 olds cutlass, 3.1 v-6, and a bad 4t60e tranny. I also have a 4t60e out of a 2003 Grand Prix. Can I swap them?
4t60e swap
Tags: None
basicly any 95-2001 4t60e, but be aware that the 4t65e came out in 97, and as the years went by, less vehciles used the 4t60e.
basicly, if its 95+ and it has a vacume modulator on it, your good. the only issue you may have is gear ratio. you need to make sure the tranny you put in has the correct gear ratio (same as whats in the car) or you end up throwing gear ratio error codes.
pponti94 what are you going to drive while you are doing this swap?? I thought you were going to school in September?!
