65 HD in a Z34
  • z34phoenix
    • Jun 2005
    • 469
    65 HD in a Z34
    besides a 97 and harness.... what would it take to get a trany from my 98 GTP to work in my 96Z34... the 97 Z34 came with the 4t65e.... being that the gtp is a 4t65-hd.
    -the trany will deff bolt up.
    -controling the trany can be done with the 97 PCM and harness.
    issues i can think of are:
    - incompatable TQ converters?
    - needing diff axles (posible to make a hybrid of my current axles and the gtp's)
    -gearing diff gtp is 2.92 and my Z is 3.43 IIRC
    the gearing i can deal with. can always try and swap gearing? even go for higher gear...
    ok time for ideas....
  • sharkey
    • Jun 2004
    • 2061
    as long as you have the 97 3.4 tdc wiring harness and computer, it shouldnt be too bad. the tranny will bolt up, torque converter will bolt up. the hd uses bigger axles, however being both w bodies they should be swapable, or at the very most have to change wheel hubs to make them fit.
    there is some varience in 4t65 gearing, however the HD uses a different diff from the non HD, so that may limit your choices unless you get into swapping the chain sprockets.
    • 3100 MPFI
      • 1522
      Also, the final drive for the 65 will REALLY SUCK in your car. The 4t60-E is like 3.33, or 3.43 and can be made to 3.73, but most of the 4T65-E is 2.86.
      Taylor
      1998 Lincoln Mark VIII
      • sharkey
        • Jun 2004
        • 2061
        the 4t60e can range 2.84 to 373 depending on the application. the 4t65e is used in a wide variety of applications from the 3400 mini vans to the 5.3l grand prix. there are more gear ratios out there than just the 2.86. heck, if you wanted you could by the race 4:1 differential from gm for the race 4t65e.
          I was thinking about doing this, but I'm a little scared of the wiring changes I may need... Do you think it would be possible for me to just add in the part I need?? and leave the rest the same?
          Only issue I see is a 97 Z34 was a DOHC motor... I would need a 3x00/4t65e ECM and bin combo... wich may push me up into the 98 realm which then I think I need to do major rewiring...
          Damn...
            • 9191
            http://www.60degreev6.com/showthread.php?t=35588
            Then just turn all the tranny stuff off in the PCM...
              PCS sells those for 700 bux...
              $525 from FAST direct though...
              Not a bad idea for when I do get the cash
              Damn I didnt even realize it controls my current trans... NICE
              • ez112
                • 258
                I heard that L67 swapped montes DID need a hybrid Monte/Grand Prix Axel. I remember because someone asked the same question for an L67 and Milzy chimed in that he could do them, and he'll them to him. I was like "bastard."
                This is why I believe that.
                1999 SVT Lightning
                1996 Monte Z34 R.I.P.
                Next BEATER: a C5
                http://www.fquick.com/ez112
                • timg
                  • Feb 2004
                  • 718
                  Axle, gearing, harness and ECU are the big ones.
                  Tim
                  325 whp 350 lb-ft
